Old 05-10-2016, 06:09 PM   #43
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
I suspect one can make an "emergency exit" out of any window by replacing the screen retaining piece with one slightly longer so as to make it easy to remove the screen. This is the only difference i can see between the screen retention methods of the windows..... Sent from my rear bed, parked in a Love's Truck Stop in eastern Indiana....LOL
Ms. Tommie Lauer
Happy trails and Good Luck
AIR #31871 WBAC #4165 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 05-12-2016, 09:59 AM   #44
2014 25' FB Flying Cloud
Fitchburg , Wisconsin
The loaded tongue weight of a FB can be 400# greater than a RF. I have a 2014 FC25FB twin with factory solar, my tongue weight is 1250# on the Airstream scale in Jackson Center. Friends have a 2014 FC25RB twin without solar, their loaded tongue weight is 800#. Neither I nor Airstream have an explanation for this. I think they know but aren't talking.
I like the FB floor plan better and the twins are definitely the way to go in either case.
If you choose an FB you will need a "3/4 ton" TV unless you carry no cargo. I started with a 2013 F-150 3.5 Ecoboost 4x4 144 WB, 3.73 axles, max tow, and max payload(great truck). I now have a 2016 GMC 2500 Duramax, not for the power but avoid overloading the tires and rear axle.
BillfromWI is offline   Reply With Quote
Old 05-13-2016, 07:12 AM   #45
GettinAway's Avatar
2011 23' FB Flying Cloud
Chesterfield , Missouri
This is interesting. On the 23s, it's just the opposite. The FB has a lot less tongue weight than the Rear BR. I think it's the weight of the bathroom, and some of the kitchen, being all in the rear of the trailer. On the 23FB FC the hitch weight, empty is only 470#..
2011 FC 23FB
2012 Toyota Tundra Dbl Cab, 5.7 4x4
GettinAway is offline   Reply With Quote
Old 05-13-2016, 07:54 AM   #46
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
With all of our mods to our 23D, the tongue weight is now 968 pounds with the Hensley Arrow attached.
Old 05-13-2016, 09:13 AM   #47
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
To get a consistent set of Airstream hitch weights there must be a consistent method of weighing the trailer at the tongue. That is not the case. Some weigh at the hitch ball, some weigh at the tongue jack, some weigh their installed Hensley/Propride at the stinger and some at the tongue jack, some trailers may not be level when weighed, some ground surfaces may not be level, some trailers are empty, some are loaded heavy in front and some are loaded heavy in back, some have bicycles above the propane tanks and see have them on the rear bumper, and some have modified their Airstreams (take us for example).
There is an important parameter we keep in mind. Airstream advises at least 10% of total trailer weight and warns to never exceed 1,000 lbs tongue weight. GVWR for our Airstream is 7300 lbs, so our trailer tongue must weigh 730 to 1,000 lbs. Sounds good, but our ProPride hitch is bolted to the Airstream tongue when we weigh it, but is carried by the truck's receiver when actually using it. So we call it a 50/50 split between the two.
Adding these various weights is a ballpark estimate. What matters to us is when loaded for travel, hitched and weight distribution set, we take it to the truck scale to ensure our truck's axles are loaded evenly and not over GAWR, our tires have enough capacity and air pressure to carry the load, and our Airstream axles are not overloaded. Some guesswork remains here because the Airstream axles are weighed as a pair, so we depend on the Airstream being as close to level as possible and loaded evenly side-to-side.
Weighing the loaded truck before hitching and then truck/trailer after hitching will give us the actual weight the Airstream adds to the truck's load, a curiosity but little else after ensuring the hitched rig is within weight limits.
Doug and Cheryl
Old 05-14-2016, 07:00 PM   #48
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
When I took my AS to the CAT scales I did a weigh-in where I unhitched and left the tongue jack resting on the one scale while the other scale measured the trailer at the wheels. I also did a measure with the trailer all on one scale and the truck on one scale. THEN I measured the hitched mess all together! I come in at around 990# tongue on a Safari 25 (2006). It would be a bit different now with the new sofa and floor and aluminum LP tanks. My guess is MORE! Don't forget to empty the WH!
I have a 2014 FC25FB twin with factory solar, my tongue weight is 1250# on the Airstream scale in Jackson Center. Friends have a 2014 FC25RB twin without solar, their loaded tongue weight is 800#. Neither I nor Airstream have an explanation for this. I think they know but aren't talking. I like the FB floor plan better and the twins are definitely the way to go in either case.
Wow, they must have put the axles further back or something. I agree with the twin layout on an Airstream as providing the better floorplan. I know many a married couple laugh at the notion but it is comfortable and couples can STILL be together!
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 05-14-2016, 07:35 PM   #49
dkottum's Avatar
Rod, those twin beds are great but crowded for two. On the other hand we'd have one bed would never got used for sleeping, maybe ditch the mattress and use it for storage.
More seriously, did you put on 30 lb or 40 lb aluminum tanks? If 40# did you use the original tank cover? We're looking at aluminum tanks, any recommendations appreciated.
Doug and Cheryl
Old 05-14-2016, 08:15 PM   #50
switz's Avatar
2014 31' Classic
Images: 8
40# Airstream aluminum tanks are taller than the Airstream 30# steel tanks. The tank cover lid on the 23D is about 5 inches below the window frame and nearly level with that frame on the Classic.
Old 05-15-2016, 09:38 AM   #51
Tomboy's Avatar
2015 25' Flying Cloud
Long Beach , California
Front Bed or Rear Bed
We did all our homework before buying, looked for years at all sorts of models and landed on the 25FB queen. Then we got a call that the dealer had gotten a new 2015 model in (everything else on the lot was 2016 by then). So we got a great deal on a 25 RB twin. We love it!
Our biggest project so far has been creating a rear lounge. We removed the top drawer from the nightstand. Then made some easily removable wood slats with aluminum support pieces that fill in between the twins. We got three small custom mattresses that fit between the twin mattresses and put down a down comforter, like a bed topper so you don't feel the seams. This created a super comfy king size bed.
Since that is way more space than we need to sleep, we added a bunch of decorative pillows. Open the curtains and it's a great place to read or hang out during the day.
We also have the option of removing only some of the slats and small filler mattresses. This can create a small place to stand at the foot of the bed. Or it can create a U shaped sitting area. Put up a small table and it's a great entertaining space for 5-6 people.
If we ever sell, the twin beds are intact and the only thing missing is the drawer for the nightstand.
The dealer quoted us $1300 to do the work, so we did it ourselves in four hours and less than $100 in material costs. The custom mattresses were the pricey part, foam with latex topper for $600.
We are both very happy with the layout, and glad we were flexible at purchase time.
Tomboy is offline   Reply With Quote
Old 05-15-2016, 10:11 AM   #52
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
That sounds very interesting. Thanks for sharing your renovation. We would love to see some pictures of it.
Brian
SuEllyn & Brian McCabe
moosetags is online now   Reply With Quote
Front Bed vs Rear Bed AS jcrango Boondocking 54 12-14-2015 09:08 AM
Front or Rear bed? I bet this has been asked a million times.... hostage46 2009-2015 Flying Cloud 45 02-04-2015 10:09 PM
Classic FB Limited (Front Bed vs Front Couch) Sky 2006 - 2010 Classic (all lengths) 38 08-07-2011 07:42 PM
Rear Queen Bed Platform/under bed storage AluminumGirl Cabinets, Counter Tops & Furnishings 0 04-18-2010 11:57 PM
Rear Bed or Rear Bath photocodo Sinks, Showers & Toilets 1 11-23-2009 05:17 PM
