02-25-2016, 11:58 AM
2007 23' Safari SE
2016 25' Flying Cloud
Anderson
, South Carolina
Dripping Sound in New 2016 Flying Cloud
We have a 2016 - 25 FB Twin, Flying Cloud and while out on our maiden voyage last weekend we would hear a dripping sound coming from the ceiling area of the bathroom. We were running the heat pump and only heard it at night when all was quiet. There definitely was not anything dripping on the roof outside. The sound was near the directional vent of the ducted air in the bathroom. Any thoughts?
02-25-2016, 12:39 PM
Jupiter
Was there water draining from the AC/HP drain tube coming out by the wheels on that side?
02-25-2016, 01:09 PM
2007 23' Safari SE
Anderson
, South Carolina
Good question....didn't think to look. Sometimes we don't know what we don't know.
02-25-2016, 01:17 PM
Jupiter
I'm pretty sure the same thing happened to us on one of our first nights, and I tracked it down to the drain tube. Hopefully that's all it is in your case too.
02-25-2016, 02:33 PM
2007 23' Safari SE
Anderson
, South Carolina
Thanks. The noise is annoying. Did it ever go away?
02-25-2016, 03:32 PM
Jupiter
I'm not sure. I will have to listen for it on our next outing that starts March 4th. It may just be that I started ignoring it once I realized it wasn't a problem.
02-25-2016, 03:33 PM
2015 30' FB FC Bunk
Ayer
, Massachusetts
Was is raining that day?
02-25-2016, 03:52 PM
ShinyPete
2014 27' Flying Cloud
Bushnell
Sometimes our shower will do that in the night. Like the water left in the hose makes it's way up to the head slowly........... Might be a possibility.
02-25-2016, 04:10 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Mike....if you heard the dripping check it out before your next outing. It is just that if it is an uncontrolled leak it could cause much greater problems the longer you wait.
02-25-2016, 04:37 PM
2007 23' Safari SE
Anderson
, South Carolina
It rained that day, but not in the pm when we heard the noise in the middle of the night. There were not any tree branches above where we had parked so it wasn't coming from the outside.
02-25-2016, 04:39 PM
2007 23' Safari SE
Anderson
, South Carolina
The shower is separate and on the opposite side of the hall so could not have been the shower hose.
02-26-2016, 12:56 PM
Stowe
, Vermont
In that model, is the hot water heater under the sink in the bathroom? When we got our new 27' FC in 2014, there was a leak in the pex pipe connection - covered by warrantee.
02-27-2016, 03:11 PM
2007 23' Safari SE
Anderson
, South Carolina
VT Wanderer, the hot water heater is under one of the beds, not in the bathroom. I did call Airstream and they said to check the vent on the roof above the bathroom to see if it was caulked adequately. We checked the roof today and everything seems fine. Won't be out again until end of March. We now think as mentioned earlier in the thread that it's condensation from the HP running thru drain line which Airstream confirmed is located in this area. We just have to wait until next trip to see if we hear it again.
02-28-2016, 06:13 AM
2015 30' FB FC Bunk
Ayer
, Massachusetts
I would fill the water tank and keep all the fixtures closed. Then wait a while to see if the pump is turning on intermittently to rule out a plumbing leak.
02-28-2016, 12:38 PM
Sag Harbor
, New York
Mike in addition to trying Ted's pump on pressure test, could you let us know how long you heard the drip? Seems like any condensate drip from the heat pump would not last more than 10-15 minutes after turning the HP off.
02-28-2016, 02:23 PM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
If it were me, I'd pull the ceiling A/C vents out and use a mirror and light to see if there is any water sitting up there or water spots anyplace on the interior skin. You could also stick your hand up there an feel around. BUT, it sounds an awful lot like the condensation hose from the HVAC unit on the roof.
Bud
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
