Old 03-10-2015, 03:03 PM   #1
1999 28' Excella
New Orleans , Louisiana
Door sun glare is annoying!
We have 2 tables in our 28' by the sofa. Mine is the smaller one by the door of course. The door glare..is there a cute solution for some elimination?
badkat is offline   Reply With Quote
Old 03-10-2015, 03:11 PM   #2
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Place mat or table cloth?
Old 03-10-2015, 03:28 PM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Close the door.
MICHAEL
Old 03-10-2015, 04:01 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Do what folks used to do in the days before insect screens were invented… hang a bead curtain in the doorway. In my neck of the woods, it's a great way to recycle old Mardi Gras beads!
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-10-2015, 04:30 PM   #5
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Move to the other table, let someone else figure out the glare solution. (you are the boss, aren't you.)
terryV is offline   Reply With Quote
Old 03-10-2015, 05:47 PM   #6
1999 28' Excella
That table is bigger..huh? Beads..love the idea and grew up in NOLA but not enough block out. Cute though!
Old 03-11-2015, 08:16 AM   #7
IanPoulin's Avatar
2011 28' International
Aldie , Virginia
Curtains
2011 Airstream International Serenity 28' - 30a/taupe
2013 Ford F150 v6-ecoboost with max tow and HD payload packages
2016 Ford F250 Crew 4x4 KR Diesel
IanPoulin is offline   Reply With Quote
Old 03-11-2015, 12:12 PM   #8
1999 28' Excella
I do not know what will hold them up!
Old 03-11-2015, 12:18 PM   #9
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Zip Dee to the rescue!
NavyCorpsman is offline   Reply With Quote
Old 03-11-2015, 12:46 PM   #10
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Your description could use more detail as to light source and when/where, but if what you are referring to is similar to what we experienced, it is easy to put a sheet of solar film on the small door window. Rather than a curtain type approach, we used a medium opaque in smokey grey to cut down on the light penetration. A small amount of soapy water and careful cutting made the end result look OEM.
I removed the film this winter and added new screen material to the inner door. I replaced the silver colored metal screen with a heavy vinyl, black, pet proof screen which has a denser weave and cuts down some of the sunlight. The particular weave I used is typically used for outdoor pool enclosures in Florida.
SeeMore is offline   Reply With Quote
Old 03-11-2015, 12:49 PM   #11
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Turn the trailer around so its the other sides problem...
Boy...and you thought we were going to be helpful
In my trailer I had snaps around the window areas that were riveted on probably so reflector screens could be popped on when the trailer was in storage to protect the interior. You could always rivet some snaps on and make a small curtain to place up when needed. Is the glare coming from the table, glass or the aluminium on the door itself?
thesignlady is offline   Reply With Quote
Old 03-11-2015, 06:53 PM   #12
1999 28' Excella
Glare is coming from the door window.
Old 03-11-2015, 08:22 PM   #13
Well, that makes it simple… I use these on my toad's windows…
http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
WBCCI #1105
TAC LA-4
Old 03-11-2015, 09:18 PM   #14
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
My Bride made a curtain with pockets top and bottom. Then we used compression rods to mount in the window.
Peace and Blessings..
Channing
WBCCI# 30676
Glare brand polish dkottum General Repair Forum 9 05-22-2015 06:30 PM
Need help on minor (but annoying) issue Lani Cabinets, Counter Tops & Furnishings 11 12-01-2009 09:45 AM
remember the annoying pop-up ad, "cereal guy"? Aage Off Topic Forum 3 06-12-2009 04:29 PM
Annoying GM ad streamer23 Forum Admin, News and Member Account Info 43 10-31-2006 12:37 PM
Another annoying lock problem - 1988 Door? Condoluminum Doors & Locks 0 07-06-2004 05:39 PM
