Old 03-11-2015, 09:29 PM   #15
bwoodtx's Avatar
1997 30' Excella
1954 22' Flying Cloud
1981 28' Airstream 280
San Antonio , Texas
I changed the screen in my door with solar screen material from Lowe's for just this reason. Easy to do and works great! You will have to use a smaller spline as the solar screen is a little thicker. Have replaced all the screens with this and it helps keep the trailer cooler.
Bruce
WBCCI# 9259 AIR# 38927 TAC-TX 14
Stop Littering-Spay & Neuter-- Adopt From Rescue
No amount of time will erase the memory of a good dog.
bwoodtx is online now   Reply With Quote
Old 03-11-2015, 09:50 PM   #16
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I cut a piece of chrome/silver bubble insulation and stuffed it into one of the empty tracks in the window frame.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 03-12-2015, 11:33 AM   #17
1999 28' Excella
New Orleans , Louisiana
Solar screen sounds wonderful..do not think we are that handy!
badkat is offline   Reply With Quote
Old 03-12-2015, 11:45 AM   #18
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Scissors cut solar screen, but if you make a pattern first, you can take your time following the cut, lay it on saran wrap and carefully apply a bead glue(silicone) after it sets, peal off the saran and put 4 dots of glue at the corners, should hold up for a few seasons.
Old 03-13-2015, 07:11 AM   #19
1999 28' Excella
Going to look into getting our screens replaced. Will be in W Va for 4 months volunteering at Stuart Rec area by Elkins. Great idea!
Old 03-13-2015, 10:03 AM   #20
Peapod
KenSanLan's Avatar
1985 31' Excella
Dade City , Florida
We were given a solution - it is an attractive fabric "pocket", same on both sides, that slips over the top of the screen door and extends down almost to door handle. This blocks light and also serves for privacy at night as the original window cover in our '85 is gone. It fits like a glove over the door - rounded on top and straight across bottom edge. Door closes perfectly.
Peapod 1776
KenSanLan is offline   Reply With Quote
Old 03-14-2015, 07:04 AM   #21
1999 28' Excella
That I could make. Thanks!
Old 03-15-2015, 08:13 PM   #22
LiLNomad's Avatar
2007 25' International CCD FB
Northridge , California
What about one of those faux stained glass decals..the removable ones (window clings? I think available at Walmart or any Michaels etc..Will let a lil light through but much softer.
LilNomad
LiLNomad is offline   Reply With Quote
Old 03-22-2015, 05:27 PM   #23
1999 28' Excella
Can try but with my luck it will not stick! Window is not smooth.
Old 03-22-2015, 05:32 PM   #24
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Window cling film can go outside or inside, and one side is bound to be smooth enough for it to stick.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 03-22-2015, 05:34 PM   #25
Salem , Oregon
Images: 18
Hi, I took a few pictures.
ID:	234762   Click image for larger version
2005 Safari 25-B
Old 03-22-2015, 05:34 PM   #26
1999 28' Excella
Will check it out..thanks! WOW that is so AS cute.
Old 03-22-2015, 05:39 PM   #27
1999 28' Excella
At Lowes r HomeDepot I guess.
Old 03-22-2015, 06:00 PM   #28
Don't have to go with chrome/silver. Even clear bubbles (available for packing packages at FedEx and UPS) will cut glare, but will still let in light.
WBCCI #1105
TAC LA-4
Glare brand polish dkottum General Repair Forum 9 05-22-2015 06:30 PM
Need help on minor (but annoying) issue Lani Cabinets, Counter Tops & Furnishings 11 12-01-2009 09:45 AM
remember the annoying pop-up ad, "cereal guy"? Aage Off Topic Forum 3 06-12-2009 04:29 PM
Annoying GM ad streamer23 Forum Admin, News and Member Account Info 43 10-31-2006 12:37 PM
Another annoying lock problem - 1988 Door? Condoluminum Doors & Locks 0 07-06-2004 05:39 PM
