Old 05-10-2019, 07:30 PM   #1
California , MD
Does a 25RB Twin Need 2 ACs?
Hi,
Looking to order a 25RB Twin and wondering is it needs 2 ACs?
Seems like it should do fine with one.
However, never having owned an Airstream, I wanted to ask.
Thanks in advance for your thoughts.
Dan
cru-in is offline   Reply With Quote
Old 05-10-2019, 07:34 PM   #2
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Lots on the forum about this topic. I think it needs 2 without a doubt. If you travel south in the summer 2 is a must.
Dept of “OverKill”
Old 05-10-2019, 07:38 PM   #3
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
From our experience, it depends on where you camp. In full sun on a hot day, our 25' FC single AC unit can sometimes only cool the AS to about 10-12 degrees lower than the outside temperature. So if it's 95 degrees it might only cool it off to the low 80's.
So we try not to camp in those conditions. If you will be regularly camping in those conditions you should get two ACs.
"A good traveler has no fixed plans, and is not intent on arriving." - Lao Tzu
SeaLevel is offline   Reply With Quote
Old 05-10-2019, 08:09 PM   #4
r carl's Avatar
Lin , Ne
With the lower reliability of the new air conditioners it would be nice to have a backup.
Old 05-10-2019, 09:10 PM   #5
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
My experience was different, for a different generation of 25. We had a 2001 Safari 25 RB twin with only an 11,000 BTU AC. Sitting in the sun, in my driveway, with 95 degree temperatures it kept the trailer comfortable, but I don't remember the temperature. It wasn't cycling, if I remember correctly, but we were never uncomfortable. It had the mouse fur walls and vinyl ceiling overhead so no exposed aluminum.
Our 2002 Classic 30 is another story. I will probably end up putting a rear unit in it.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 05-10-2019, 10:14 PM   #6
2016 26' Flying Cloud
Southlake , Texas
Question
I would definitely recommend two. We have replaced both of our units TWICE! It would have been miserable without any a/c.
I hope we don't have any more failures!
Barry
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
WBCCI
Bgibbs is offline   Reply With Quote
Old 05-10-2019, 11:45 PM   #7
wulfraat's Avatar
2017 30' International
Broomfield , Colorado
Two no doubt
wulfraat is offline   Reply With Quote
Old 05-11-2019, 01:38 AM   #8
2016 30' Classic
Lorton , Virginia
I always recommend two.
1. You have a backup
2. You can turn on the AC opposite to where you are in the trailer for less noise. Even with them being duct'd, still loud enough to be annoying (to me at least).
Zybane is offline   Reply With Quote
Old 05-11-2019, 05:04 AM   #9
Acheron2010's Avatar
2019 26' Flying Cloud
Morristown , Tennessee
I'm in a 26 with two, and I like it because,
50 amp service. I can use 30. But if I have only 30, I cannot use 50.
Sometimes I want it quiet in the lounge area, so I run the AC unit on the opposite side.
Having a backup is awesome. Two is one, and one is none.
In 100+ degree days, I can run two and get in the mid-70's inside.
Two heat pumps for those cold days.
2015 Chevrolet Silverado 2500
2019 Airstream Flying Cloud 26RBQ
WBCCI #6679
Acheron2010 is offline   Reply With Quote
Old 05-11-2019, 07:01 AM   #10
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Maybe it depends upon whether you view the trailer as a tent on wheels or a mobile luxury condo.
Bill M. is online now   Reply With Quote
Old 05-11-2019, 09:11 AM   #11
2018 27' Globetrotter
Orlando , Florida
2 Air Conditioners.. Yes!
We have 1 unit, Non-Ducted on our 25 Safari SE.
1. These things break. 2 is better than 1.
2. you can use them as needed.
3. Re-Sale. Nobody keeps these forever. Don't be cheap with Comfort issues.
4. Hot Weather. You'll be glad you did it!
Safe Travels!
Bobfrapples is offline   Reply With Quote
Old 05-11-2019, 09:25 AM   #12
St Petersburg , Florida
1 or 2 AC units?
Sleeping in the heat.....
During summertime in Maine and Nova Scotia, one is adequate.
During summertime in Arizona and Texas, two is almost mandatory.
From a re-sale perspective, having two is always better.
Be well and "sleep cool"
PirateChris
PirateChris is offline   Reply With Quote
Old 05-11-2019, 09:54 AM   #13
Cloudland2
davidrrand's Avatar
Trenton , Georgia
We've had our 2016 25RBTwin since May of that year. We avoid camping during the heat of the SE where we live in NE GA and travel out west in the mountains in late summer and fall. One has worked well for us. For those who camp in the hotter months wherever, two would be wise.
davidrrand is offline   Reply With Quote
Old 05-11-2019, 10:06 AM   #14
gypsydad's Avatar
2017 28' Flying Cloud
2014 25' FB Flying Cloud
2008 25' Safari FB SE
Austin (winter) Lincoln MT (summer) , Texas & Montana
We have owned 3 25' AS's; all had only one, 1500AC unit, so we did not experience the value of having 2 AC's. Even on our camp trips in Texas heat and California desert, it wasn't an issue...since we did not have 2 AC's. It took awhile in those hotter climates to get us comfortable, for sure, but that's all we had.
Fast forward- the dealership here in TX started ordering 25's with 2 units about 8 years ago, as I recall; now they order all 25' and larger AS's with 2 AC's, unless a customer requests a special order of one.
We have 2 in our 28', and I am glad. We mostly use the second unit to cool our AS faster when in hot climates, then we will select just one for maintaining the temperature we are comfortable with, especially true at night... If I were doing it again, I would get 2; better resale also.
2017 28' Twin Flying Cloud
2017 F250 King Ranch, 4X4, Blue-Ox WDH
Summer in Lincoln, MT- Winter in Austin, TX
Wanted: Flying Cloud 25RB Twin or bigger johndoyle02 Airstream Classifieds 0 05-05-2019 09:45 AM
Bunk Beds In 25RB Twin FC? shmegy 2016 - Current Flying Cloud 10 12-14-2017 06:46 AM
The Holy Grail of the ACs VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 39 09-16-2013 06:14 PM
Running 2 ACs on 30 amp w/ auto select? airdoc Furnaces, Heaters, Fireplaces & Air Conditioning 9 03-21-2013 02:00 PM
Flying Cloud 25RB Twin mattesses clicker187 2009-2015 Flying Cloud 0 12-02-2012 11:56 PM
