Old 08-20-2015, 08:05 AM   #1
Big Air's Avatar
Decorating Your Airstream
I am getting ready to decorate the walls of my new air stream. I plan on hanging my decorations above the front and back windows which means on the white Formica walls. At least I think it's Formica. I don't really want to ruin the walls and do permanent damage. Any ideas
While we are on the topic, what about the aluminum walls also??
Big Air is offline   Reply With Quote
Old 08-20-2015, 08:15 AM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Formica? I don't think I have seen that originally used on the walls. I use 3M Commend strips for most interior projects. Easy to apply, remove and no marks left.
MICHAEL
Old 08-20-2015, 08:27 AM   #3
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Yup, 3M Command strips.
Old 08-20-2015, 08:56 AM   #4
2015 23' International
Charleston , South Carolina
Ditto. Available at Lowes. Lots of different hook configurations for various sizes and weights.
FollySteve is offline   Reply With Quote
Old 08-20-2015, 10:28 AM   #5
2000 25' Safari
2001 27' Safari
Bakersfield , California
So, we just overhauled an Airstream and wall decoration was a concern for me too. I used 3M Command product to hang pictures. No holes, no tape marks, no damage. It works on the cabinets and padded vinyl walls but not so much on "mouse fur" walls. I'm pretty sure it would also work on aluminum too.
CathiDG is offline   Reply With Quote
Old 08-20-2015, 10:32 AM   #6
2014 27' FB Classic
Cassopolis , Michigan
On the "mouse fur" walls just stick the hook side (i.e., not fuzzy) of Velcro to the back of your picture/clock/key holder/whatever and stick it to the mouse fur. Magic. Can be easily removed or relocated. Does not damage the "fur."
biyak269 is offline   Reply With Quote
Old 08-20-2015, 10:40 AM   #7
PammieSue's Avatar
1988 32.5' Airstream 325
Vista , California
Command Strips do not stick on Airstream wallpaper; does anyone have advice for hanging items on that?
Dysfunctional Veteran- does not always play well with others. 20 a day is 20 TOO MANY.
(Approximately 20 Veterans commit suicide everyday. Revised from 19; revised from 20; revised from 23; revised from 22. Even the VA is a work in process)
PammieSue is offline   Reply With Quote
Old 08-20-2015, 10:52 AM   #8
1989 25' Excella
Torrington , Wyoming
I did use the Command strips on the vinyl wallpaper in the bathroom. I made sure the vinyl was super clean and dry before applying the strips. I, also, let it "sit" for over 24 hrs. before hanging any weight on it. They are still up working even after the heat of summer and cold of winter. I wondered if it would really do the job...but the Command strips worked beautifully.
HighPlainAS is offline   Reply With Quote
Old 08-20-2015, 11:17 AM   #9
PammieSue's Avatar
Vista , California
I tried both command strips and 3M's permanent double sided wall mount tape. Of course I did the cleaning, and waiting for 24 hours before using. Both failed when hanging only a summer straw hat. Command Strips work well on wood and painted dry board, but this vinyl wallpaper? Nope. *sigh*
Old 08-20-2015, 12:45 PM   #10
AWCHIEF's Avatar
Images: 33
Prep the surface with alcohol and wipe dry before attaching command strip.
MICHAEL
Old 08-20-2015, 12:49 PM   #11
firstwave's Avatar
2006 30' Classic
Santa Fe , New Mexico
Command strips would adhere to my vinyl but tended to pull the wallpaper away from the wall.
firstwave is offline   Reply With Quote
Old 08-21-2015, 04:51 PM   #12
PammieSue's Avatar
Vista , California
Yeah, tried that the second time and still no luck.
Old 09-07-2015, 11:04 AM   #13
Firstwave: had a similar problem with a picture hung on "orange peel" wall. Took a big chunk of it when the picture fell down. Human error: picture too heavy for hook. I tried again, after repairing wall, with actual picture hanging version, weighed pic to make sure it wasn't too heavy. Works like a charm. They even have heavy duty hooks for shower use now. Shoulda bought 3M stock.
YoYosMum is offline   Reply With Quote
Old 08-09-2016, 08:28 AM   #14
2015 23' Flying Cloud
Livermore , California
What do you mean by "airstream wallpaper"?
cactusjk is offline   Reply With Quote
Need Decorating Ideas 31airstream General Interior Topics 26 09-17-2014 10:42 AM
Organizing/Decorating Ideas UtahChic General Interior Topics 4 01-22-2012 11:04 PM
Organizing/Decorating Ideas UtahChic Interior Restoration Forum 0 01-21-2012 11:03 PM
Decorating Int'l CCD Interior Marina 2002 - 2005 International 8 10-01-2008 02:43 AM
decorating without damage? Roamin Cat Cabinets, Counter Tops & Furnishings 4 04-15-2008 11:44 AM
