Originally Posted by disherb
hi guys, iam looking for some sew in curtain slides for a 1969 airstream they are two types top and bottom please help thanks.
The original 1969 drape tab was spring loaded and cost over a couple of dollars each.
Most likely then, someone upgraded your drape tracks with the new style.
The new style uses "T" as well as "G" tabs, as you see them from the side.
Or, perhaps they used the early 70's type which is directly sewn on to the drapes. Those are called Kirsch tabs.
Not to confude you, but which ones do you now need?
