Old 04-01-2015, 06:41 AM   #1
Manheim , Pennsylvania
Colonial Orientation
We will be picking up our AS very soon at Colonial. They said it would take 2 hours to go over everything. I know many forum members have done this, any comments or advice on what to expect?
Jukeboxfun is offline   Reply With Quote
Old 04-01-2015, 06:45 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yes it can take that long- they won't rush you and want to make sure you understand everything. Take your time, don't be in a hurry so you can absorb it all.
2012 Dodge Durango Hemi/AWD
Old 04-01-2015, 06:47 AM   #3
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
Kevin Amaro will probably do your orientation.
If you've got a smartphone, you might ask him if you can use it from time to time.
There's a lot of stuff to go through if you've never had an Airstream.
His walkthrough will be very thorough.
Congrats on your new AS!
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 04-01-2015, 06:49 AM   #4
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
We had our orientation at Colonial as well. If you are a newbie to RV'ing, two hours is a bit short. Our orientation took closer to four hours. The people at Colonial are great.
You will be overwhelmed with information. If you can, use your smartphone to record some of the more critical parts of the orientation, like how to hitch and unhitch. Take notes. And mostly don't worry. There are a lot of YouTube videos out there to help remind you of what you were shown and there is always this Forum!
I will caution you that Colonial is located in a very congested part of NJ. Your inaugural tow will be on some of the busiest roads in the country. And then of course there is perpetual road construction. Plan your route out of Colonial carefully and know where you are going. We got lost right out of the parking lot because the GPS we had had not yet oriented itself properly and we turned left instead of right. If you can avoid I-95 I would recommend that.
Of course, if you are a RV expert, you won't have any problems at all.
Bob Martel
WBCCI# 5766
Old 04-01-2015, 06:53 AM   #5
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
While using phone to video don't forget to actually listen to what you are being told. Better yet have someone else video the presentation so you can concentrate.
MICHAEL
Old 04-01-2015, 06:58 AM   #6
Chelsea , Michigan
Images: 12
Excellent point, in our case I listened and my wife was the videographer.
Bob Martel
WBCCI# 5766
Old 04-01-2015, 08:11 AM   #7
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have not chosen an escape route I would suggest the following.
Right out of Colonial to left light on 623 New Hampshire Ave. a long block. New Hampshire to left at light on Cedarbridge Ave. again a long block Cedarbridge to New Jersey Parkway North. about a 1/2 mile. NJPW north to 195 west, 8 miles. West 28 miles on 195 to New Jersey Turnpike. South on TP to Pa.
You do not want to tow west through Lakewood.
2004 Excursion 4x4
Old 04-01-2015, 10:06 AM   #8
Chelsea , Michigan
Images: 12
Can you bring a trailer on the Parkway? Last time I looked many many years ago I thought this was prohibited.
Bob Martel
WBCCI# 5766
Old 04-01-2015, 10:09 AM   #9
Wayne&Sam's Avatar
Images: 21
Yes you can.
Old 04-01-2015, 10:14 AM   #10
Chelsea , Michigan
Images: 12
Originally Posted by Wayne&Sam View Post
Yes you can.
Good to know!
Bob Martel
WBCCI# 5766
Old 04-01-2015, 10:17 AM   #11
Sorry, I looked at Google maps and I can't follow your directions. I just figured back home same way I go down 88 back to route 9 to 195 njtunpike to pa turnpike.
If you can clarify, I welcome a different route.
Old 04-01-2015, 10:18 AM   #12
2007 27' Classic FB
Ridgefield , Washington
If you are new to RVing I would defiantly video hitching and unhitching. Using the Fantastic fans and hooking up electrical and sewer.
John & Lisa
Woosch is offline   Reply With Quote
Old 04-01-2015, 10:27 AM   #13
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Make sure that they show you the circuit breakers and 12 volt fuses. Also have them point out any GFCI outlets that may need to be reset.
Also have them show you the control buttons on the refrigerator, and how the operate and what signals show on the panel.
Brian
SuEllyn & Brian McCabe
Old 04-01-2015, 11:13 AM   #14
Chelsea , Michigan
Images: 12
Once you've used the trailer a couple of times, you'll find that the most complicated things to master are the radio & television!
Bob Martel
WBCCI# 5766
Definitive AS Book / Video orientation for the Tradewind? pxlchk1 1970-79 Tradewind 9 02-08-2012 07:13 PM
Outrigger Orientation MDSilverado Repairing/Replacing Floor &/or Frame 8 06-11-2010 06:36 AM
Torsion Axle Orientation - '93 Excella 34' binkers Axles 7 02-04-2008 12:59 PM
Lower Compartments - orientation of locks philippes Classic Motorhomes 1 07-25-2007 09:33 AM
LP Tanks Orientation Streamer1 LP Gas, Piping, Tanks & Regulators 22 12-18-2006 04:23 PM
