Old 04-01-2015, 12:38 PM   #15
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Originally Posted by AnnArborBob View Post
Once you've used the trailer a couple of times, you'll find that the most complicated things to master are the radio & television!
ROTFLAMO - too true.
Old 04-01-2015, 01:01 PM   #16
HowieE's Avatar
Princeton , New Jersey
Images: 12
Originally Posted by Jukeboxfun View Post
Sorry, I looked at Google maps and I can't follow your directions. I just figured back home same way I go down 88 back to route 9 to 195 njtunpike to pa turnpike.
If you can clarify, I welcome a different route.
Look again. You don' want to tow through Lakewood and up route 9 unless you are comfortable towing with lots of traffic lights and strange pedestrians.
Search Colonial Airstream on Google and follow the instruction out of their lot.
2004 Excursion 4x4
Old 04-01-2015, 01:06 PM   #17
HowieE's Avatar
Images: 12
Can you bring a trailer on the Parkway? Last time I looked many many years ago I thought this was prohibited.
The southern section allows trailers.
2004 Excursion 4x4
Old 04-10-2015, 08:57 AM   #18
Manheim , Pennsylvania
We are at colonial now! Early for our appointment having coffee.
Jukeboxfun is offline   Reply With Quote
Old 04-10-2015, 10:08 AM   #19
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
A very exciting day for you!
Enjoy, relax and take everything slowly.
You will be fine!
Bob Martel
WBCCI# 5766
Old 04-10-2015, 11:10 AM   #20
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
How exciting! Have a great time.
Brian
SuEllyn & Brian McCabe
Old 04-10-2015, 11:31 AM   #21
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I'm not sure how thorough Colonial AS is on their walk through. I have some suggestions.
Have them fill the water tank and water heater and test out the hot water heater operation. Listen to the water pump. If all faucets are off then listen to hear if the pump burps now and then indicating a water leak at a fixture. I'd run the shower faucet and direct the spray on the inside against the shower door frame flashing to verify the water doesn't leak to the hallway floor. Have them test the black water flush too. Have them turn on the fridge the day before pickup so you can put a thermometer in the there while you start the walk through. Bring a multimeter to test the battery voltage when connected to shore power. It should match the output from the charger. Have them turn on the AC/Heat Pump and verify air is coming out of all ducts uniformly. Ask them to weigh the hitch so you have an idea what the tongue weight is prior to hitching up. Have them verify the tire pressures. Open and close every window and vent. Bring a DVD and have them show you how to display to the TV and play the audio through the system. Also play off the air broadcast on the TV and have them direct the TV audio to the radio speakers.
Good luck and have a great time
Kelvin
Old 04-10-2015, 11:43 AM   #22
Landrum's Avatar
2014 25' FB International
Little Rock , Arkansas
Be careful.....that excitement can be addictive!
Landrum is offline   Reply With Quote
Old 04-11-2015, 07:01 AM   #23
Big day yesterday. Towed the new Flying cloud from Lakewood, NJ to Manheim PA. This was only the second time I ever towed a trailer. I made it home, parked it in the driveway in one try. Yeah right LOL!
Old 04-11-2015, 07:05 AM   #24
FCloud9's Avatar
Mohnton , Pennsylvania
Congratulations on your new Flying Cloud!
Noticed we are practically neighbors....enjoy your new Airstream,
FCloud9
FCloud9 is offline   Reply With Quote
Old 04-11-2015, 07:34 AM   #25
Hans627's Avatar
2009 25' FB International
2018 27' Globetrotter
Hanover , Pennsylvania
Congrats. It was big day indeed.
How did your RAM handle the tow?
Old 04-11-2015, 07:51 AM   #26
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Glad you made it. NOW you know why New Jersey put the "FF" in traffic. If you handled it without a meltdown you can handle anything any other state can throw at you. If you traveled RT 78 westbound and went through the high speed EZ-pass lane be prepared to check your EZ-pass account in a few days and check the charges. If you went any other route you should be OK.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 04-11-2015, 08:05 AM   #27
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Very nice!
2012 Dodge Durango Hemi/AWD
Old 04-11-2015, 11:28 AM   #28
Name:	ImageUploadedByAirstream Forums1428773272.467544.jpg
ID:	236050taking a break
Definitive AS Book / Video orientation for the Tradewind? pxlchk1 1970-79 Tradewind 9 02-08-2012 07:13 PM
Outrigger Orientation MDSilverado Repairing/Replacing Floor &/or Frame 8 06-11-2010 06:36 AM
Torsion Axle Orientation - '93 Excella 34' binkers Axles 7 02-04-2008 12:59 PM
Lower Compartments - orientation of locks philippes Classic Motorhomes 1 07-25-2007 09:33 AM
LP Tanks Orientation Streamer1 LP Gas, Piping, Tanks & Regulators 22 12-18-2006 04:23 PM
