Old 05-19-2017, 08:42 AM   #15
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Thanks Rich, I just found that on the order guide, 400 or 500 lb boost to GVWR with max tow. Now if only the 1500 was available with a 36 gallon tank.
Larry
lsbrodsky is offline   Reply With Quote
Old 05-19-2017, 08:45 AM   #16
dznf0g's Avatar
Oswego , Illinois
Larry
Interesting, I just had that 36 gallon discussion with the Brand Manager on Wednesday....along with, I want another 400# payload with MaxTow. Been pushing that for a couple years...we'll see what happens in the next Gen truck.
-Rich-
Old 05-19-2017, 08:54 AM   #17
lsbrodsky's Avatar
The OP has a great truck for towing an AS, except for fuel capacity. My next truck is going to require more than 26 gallons and I do not want to buy a 2500HD. I have never owned a FORD but my next truck will be a FORD 1/2 ton if GM does not match the FORD options. I am going to hold out for 2-4 years.
The OP can easily carry what he wants to carry, but he is going to need to stop for fuel on a long day of driving..that is just not consistent with the competition.
Larry
Old 05-19-2017, 09:21 AM   #18
AirstreamCSH's Avatar
2016 25' Flying Cloud
Huntington , New York
You have a great truck for what you are looking to do. Only advantage diesel would have given besides exhaust brake and torque is that you could have added a titan spare tank in the bed to carry extra diesel but stopping for gas shouldn't be a drawback that messes you up. Have fun.
AirstreamCSH is offline   Reply With Quote
Old 05-19-2017, 10:34 AM   #19
2013 25' International
Boise , Idaho
Thanks everyone!
Super appreciate all of the help.
I've been dreaming of the day I have an airstream for many years, and now I'm likely just a couple of days away!
-Adam
afk314 is offline   Reply With Quote
Old 05-19-2017, 10:59 AM   #20
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Good Morning, Adam
As a fellow Idahoan I'm gonna tell you to ignore advice from flatlanders, and go with a bigger engine if you can. I have towed my little 5,000lb 20ft FC all over (including up Vail Pass) with my 2005 Yukon and 2012 Tahoe (both with the 5.3L engine), and its not fun to sit there while you lose the power to get you up our mountains (think Rt. 21 up to Idaho City and Stanley), and listen to the constant shifting and high revving. Traded my 2005 Yukon for a used 3/4 ton Suburban. Tho nowhere as nimble as our Tahoes/Sierras, it does a much better job. This is my advice despite you'll now get a bunch of responses showing that the new 5.3L GM engines are actually more powerful than my 6 year old 6.0L. In either case, safe travels. jon
B00merang is offline   Reply With Quote
Old 05-19-2017, 11:37 AM   #21
2016 27' Flying Cloud
Hendersonville , North Carolina
Just for a reference point, I use my 2014 w/ 5.3 w/ 3.73 gear to pull up two fairly steep grades near my home. One is 6% for 3 miles and the other is 6% for 6 miles with several turns. These are known as the Old Fort and Saluda grades near Asheville, NC. ( I think I got those specs right but you might want to check to make sure my numbers are right)
My truck has no problem keeping the speed limit (55) I have been up the Old Fort Grade at 60mph also with no troubles.
Maybe in Idaho you have longer and steeper grades but no issues for me hauling my rig over Monarch pass in Colorado either. My dad has the 6.2 and yes it pulls better and has a little more payload but due to premium fuel, I think I would make the same choice again.
I'm not trying to advocate a 1/2 ton over 3/4 ton as the 3/4 is obviously better in every measure for towing. I think for the O.P.'s sake it is important for him to know that his current truck can adequately do the job he is asking of it if he wants to keep that truck in my personal opinion. If you want to upgrade to a 3/4 ton than by all means. Hook it up and forget it. The new HD trucks are beautiful!
My experience only. Yours may vary. Safe travels and enjoy your Airstream!!
TylerWilcox is offline   Reply With Quote
Old 05-19-2017, 01:32 PM   #22
2000 30' Excella
2014 30' Classic
Princeton , Iowa
You will do fine
I pulled a 30' Classic with my Chevy 5.3 and it did fine. I pulled it over 20,000 miles.
larryglarson is offline   Reply With Quote
Old 05-19-2017, 02:41 PM   #23
1996 25' Excella
Tillsonburg , Ontario
Smile
Originally Posted by GMFL View Post
You will be fine. There are people on this forum that would pull that trailer over the continental divide with a VW Bettle rebuilt by CanAM, running on E85 fuel, rolling on GYM tires without a TPMS
Right On! and uphill both ways in the snow
5.3 might be a bit light on the upside of the hill. Has about the same HP/torque as my 4.7 Mitsubishi engine
JCW
JCWDCW is offline   Reply With Quote
Old 05-19-2017, 07:50 PM   #24
Alluminati's Avatar
St. Louis , Missouri
Considering that your towing limit is 11K, compared to your carrying capacity of 2.1K, that means your truck can pull 5 times more cargo than it can carry.
Keep that in mind when loading excess freight. It would be easier on your truck if you packed it all in the trailer.
The Morgans
1989 Avion 34VB, "QE3"
2008 Toyota Sequoia 5.7L "Tug"
(Is there no respect for an 8-ton GCVWR truck? *sniff* )
Alluminati is offline   Reply With Quote
Old 05-19-2017, 08:58 PM   #25
Half a Rivet Short
Carlisle , Pennsylvania
Hi
If you are comparing towing over the Rockies at > 11,000 feet to running over the same grade at 1,000 feet back east .... that's not a fair comparison. You likely have 20% less power at the higher altitude. Yes, it's a "that depends" sort of thing so it's only a rough number. Been there and done that both places a number of times. The thin air has an effect.
Old 05-20-2017, 07:34 AM   #26
2017 22' Sport
connelly springs , North Carolina
You will be just fine. I have pulled a similar rig with my 2014 Silverado, crew cab, short bed, 5.3 engine with no problems. I did put in rear air-lift air bags and a rear anti-sway bar. I replaced the wrangled radicals with Michelin LTE 265/60R 20 tires....big improvement (e rated tire). I use a Blue-ox hitch an it all seems good.
rustyoldman is offline   Reply With Quote
What size drop down for GMC Sierra GMC 2500hd? JJ1 Tow Vehicles 4 11-15-2016 04:50 PM
Further experience with GMC Sierra 1500/6.2/max trailer tow pack truck DC Bruce Tow Vehicles 31 11-14-2015 07:52 AM
GMC Sierra engine choices and more Distantdrummer Tow Vehicles 5 07-18-2010 01:46 AM
2003 GMC Sierra 1500 and Safari SE 23FB machead Tow Vehicles 6 03-26-2010 11:16 AM
2008 GMC Sierra 1500 2wd MaxVortex subfan1 Tow Vehicles 10 05-03-2008 10:08 PM
