Old 08-25-2014, 03:47 PM   #1
Best truck to tow 25 ft trailer
Rhodies is offline   Reply With Quote
Old 08-25-2014, 04:06 PM   #2
Garfield's Avatar
2001 25' Safari
London , Ontario
Images: 24
I'd suggest the "best truck" is the one you like best. In fact ANY truck that I know of will tow a 25 footer...as will many SUVs, minivans and even some sedans. Buy the one you like best.
Gary & Debbie
2001 Safari 25 SS
2011 Chevy Traverse 3.6L AWD Hensley DirecLink McKesh
Set-up by Can-Am RV
Garfield is offline   Reply With Quote
Old 08-25-2014, 04:13 PM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
If you want a truck (based on your post) I would suggest that you consider the Ford F-150 Ecoboost. It's relatively economical, can pull any Airstream, and has enough oomphf to get up the hills.
Bob Martel
WBCCI# 5766
Old 08-25-2014, 04:15 PM   #4
r carl's Avatar
Lin , Ne
Best as far as what?
Old 08-25-2014, 05:13 PM   #5
1987 25' Sovereign
Oregon , Ohio
I towed our 87 25' Sovereign for three years with a F150 super crew with a short bed. It did well from Florida to Ohio to Dallas and back. Then last year we got a F250 extended cab with a long bed. it gives us the same fuel millage as the F150 at towing speed, and is much more stable than the F150 when towing
msmcv51 is offline   Reply With Quote
Old 08-25-2014, 05:39 PM   #6
dougandlori's Avatar
2004 28' Classic
Fresno , California
My 08 Tundra Limited has served me well for two years and 3 Airstreams. 2-25' and 1- 27'.
The Tundra is paid for so there is no reason to change. The Airstreams have been 1990 Excella, 1999 Safari and now a 25' 1995 Excella.
Doug & Lori
Fresno
2004 28' Classic
2007 Ram 2500
dougandlori is offline   Reply With Quote
Old 08-25-2014, 06:46 PM   #7
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Everyone knows the best truck is the right truck for the job.
heh... see what I did there.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 08-25-2014, 06:54 PM   #8
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
A new Ford F350 diesel! The only thing to watch out for is when on an uphill grade don't apply to much throttle , you risk stretching the frame on the TT!
sheriff1 is offline   Reply With Quote
Old 08-25-2014, 07:24 PM   #9
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
Images: 8
This is a loaded question of subjective responses but, my used truck hunting led me to a Ford F150. I will attempt to answer the question rcarl posed as to why it, for me, was the best choice. I was shopping the 2-3 year old model year at the time. What I learned about towing setup of the various manufacturers was what swayed me. I shopped Tundra, Chevy, Dodge and Ford. In THAT vintage, Ford won as a tow vehicle with the most feature set for towing. The videos are still on youtube about towing and the 2009 model. Standard transmission braking with two taps on the brake, easily reachable brake controller. auto sway correction through multiple braking, etc. The others had one or maybe two of these or in one case, none. That and payload capacity of the ones on the used market locally at the time made my decision.
So, a similar situation may happen to you. Just make sure that your payload rating is not violated. The tow rating is rarely a concern.
WBCCI 8653/AIR 60240
2017 Ford F-150 3.5 Ecobeast Gen 2 3.55 Platinum
Old 08-25-2014, 08:16 PM   #10
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
A 25' Airstream is medium size so a medium size truck is a good match, if you don't carry a lot of people and gear in the truck while towing due to payload limitations.
Late model 1/2 ton with about 400 ft/lb torque, 6 or 8 speed trans, factory tow package, brake controller, and LT or XL tires hooked to the Airstream with a Hensley/ProPride style hitch makes a good, comfortable, easy driving combination.
Doug and Cheryl
Old 08-26-2014, 10:46 AM   #11
2016 30' Classic
Erie , Colorado
Kenworth T680 pulling a lowboy and you can pull the Airstream onto the bed. No chance of GYM blowouts... It must be the first of April...
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 08-26-2014, 11:27 AM   #12
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I'm satisfied with my 2010 Toyota Tundra SR 5.7 double cab 2x4 pulling my 2008 25fb Classic 25fb. I bought preowned (Tundra and AS). Can't ever see buying new.
Kelvin
Old 08-26-2014, 11:47 AM   #13
Goal15's Avatar
Dallas , Texas
Hey Kelvin
glad the Tundra/25AS is working out for you.
We would like to upgrade (someday) to a 25fb but probably in an international or FC and it sounds like if you are pulling a Classic with all those wood cabinets that the Tundra would be plenty of truck for the other models.
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 08-26-2014, 12:19 PM   #14
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
If you want something comfortable when not towing get a big SUV.
John & Vicki
WBCCI #4291
Grown men don't need leaders. ~ Edward Abbey
John&Vicki is offline   Reply With Quote
Generator in tow truck bed-wiring the trailer safariuser Batteries, Univolts, Converters & Inverters 6 02-06-2013 11:00 AM
What's the Best Tow Truck for a 30' Excella 1000? SSChanger Tow Vehicles 4 06-18-2009 09:04 AM
Best Old Trailer for 2006 Tacoma V6 Truck? barbara4rb Member Introductions 3 06-03-2007 08:25 AM
Renting a tow trailer/truck? pinkflamingoes Tow Vehicles 13 05-15-2004 06:10 PM
