Old 09-19-2013, 08:53 AM   #1
slimhawg's Avatar
Sunrise , Sunset
Air Compressor?
Do you carry an air compressor for tires?
I'll have my two Honda Gens in the bed of the truck and I'm trying to decide if I want to add the weight of a compressor.
Steve
slimhawg is offline   Reply With Quote
Old 09-19-2013, 09:01 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
I carry one. Those dinky little 12v compressors that plug into a cigarette lighter/power outlet take forever to air up tires to over 60psi, so I went with one that runs on 120vAC and can handle up to 150psi. I can run it off my generator if necessary.
Mine is a 1.5-gallon Craftsman compressor that I picked up at my local K-mart. It's not all that heavy; only weighs 25 pounds.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Protagonist is online now   Reply With Quote
Old 09-19-2013, 09:13 AM   #3
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
This rides in the back of the Suburban next to the Honda 2000. Its 120 +/- PSI.
Bought it used and was badly scratched up. Plus, sometimes I just get bored in the shop!
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 09-19-2013, 09:26 AM   #4
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
I have an air chuck on the back bumper beside the license plate along with a three gallon air tank due to the level ride air bag suspension system.
Old 09-19-2013, 09:44 AM   #5
mstephens's Avatar
2013 25' Flying Cloud
Cat City , California
I carry a 12V compressor. It can add 5 pounds in about 2 minutes, which seems strong enough for most use. It only weighs a couple pounds.
mstephens is offline   Reply With Quote
Old 09-19-2013, 10:29 AM   #6
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
As some others do, I carry a small 110v air compressor with tank on our trips since I have the Honda generator along with us anyway.
It is however a very noisy little sucker compared to the larger compressor/tank I have in the garage. I believe it is a diaphragm type rather than a piston compressor. If I had to replace it, I would look to see if I could find a small piston unit instead for that reason.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 09-19-2013, 10:33 AM   #7
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Wish we had room to carry a 120v compressor to run with the genny, but we don't have the room to spare. So we carry a small 12v compressor that works great for topping off the tires when necessary...it does the job.
TB & Greg and Abbey Schnauzer
#3954
Old 09-19-2013, 10:52 AM   #8
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
Images: 8
Our 120v Compressor Choice
We carry a small Senco and use it quite often on the road.
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-19-2013, 11:12 AM   #9
2004 25' Safari
prattville , Alabama
Compressor
I carry a Viair 88P runs on !2 volt has battery clips up to 120 PSI Built in Gauge 8 ft. cord 12 ft. hose. Small size 10 inches long Appx. 5 Lbs that is a best guess on weight. works well cost was $80.00 amazon. there larger and smaller versions but this size was a good fit in that the next version up cost almost twice with the biggest upgrade is a longer hose. and a carry bag. works well. stores under the rear seat of my 2006 dodge 2500 crew cab 5.9 diesel.
bearrand is offline   Reply With Quote
Old 09-19-2013, 01:20 PM   #10
slimhawg's Avatar
Sunrise , Sunset
Thanks everyone. I think I'll take the compressor.
