Go Back   Airstream Forums > Airstream Community Forums > Airstream Lifestyle
Old 06-30-2015, 08:10 AM   #1
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
AHA! Moments: What Have You Learned Lately?
I've been at this for a couple of years now with 12,000 miles and perhaps 300 nights in the trailer. I'm starting to feel more competent but staying aware that there is still much to learn. Here's a current example.
I went to pick up the trailer last night as we're getting ready to spend a week or so at the Oregon Coast. It's 100 degrees here in Central Oregon. At 4,000' it seldom gets to over 90 degrees so we're a little wimpy when it comes to heat. Anyway when I toggled the jack switch to lift the tongue - nothing - the batteries were dead. Very surprising as I have left the trailer for months in the winter with no problems. The heat maybe?
Well, I started with the hand crank, a tedious process that takes forever. Then I had a thought - maybe if I hooked up the umbilical to the TV things would be powered by it. Voila! It worked great. Probably pretty obvious to most of you folks who are much more experienced than me, but I was delighted.
I'm really interested to hear what others have learned in these type of Aha! moments. I'm off to check the fluid level in the batteries.
Cheers,
John
John Audette
Air Cooled Porsche Specialist -
Two roads diverged in a wood, and I took the one less traveled. ~ Robert Frost
John&Vicki is offline   Reply With Quote
Old 06-30-2015, 09:41 AM   #2
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
Here's another one of mine...
When I first got the trailer I thought the awning only extended two notches. I thought it odd that it was so low that the door rubbed on it. I even bought one of the little wheels from ZipDee to mount on top of the door. Only later did I learn that there was a third notch which enabled further extension of the awning.
Cheers,
John
John Audette
Old 06-30-2015, 10:16 AM   #3
"Cloudsplitter"
Wink
When your co-pilot brings something to your attention while they are behind the wheel that you had not noticed.......it's worth a thorough investigation.
"...I don't know, it just feels different than when I drove before"
Right WD Hensley jack set for heavy load.....left not so much.
Old 06-30-2015, 10:33 AM   #4
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Cheers,
John
So far, I've discovered 4 notches in mine - I'm afraid to look for a 5th but the 4 clears the door!
BTW - on a Front Bedroom trailer, the offset (4 on one side, 3 on the other) for rain, dumps the runoff in your outdoor living area since you have to use the 4 next to your door 😳
Haven't had an aha for that yet - but hope to...
Here's one that is obvious now but wasn't 2 years ago. Check side to side level BEFORE unhitching 😃
Great thread, OP!!
Old 06-30-2015, 10:47 AM   #5
Rich W's Avatar
I'm In , Kentucky
Cheers,
John
Add me to this list. For our first few trips I thought I was doing it right but something was installed incorrectly. I used a 20 oz. Vitamin Water bottle up under the awning cover to give me that extra inch so we could open the door. One day, with the AS out in front of the house, the wife decides to read the manual (men, of course, never resort to this) and said that
a.) you've got the rafters in the wrong place (rafters? I say. What are the rafters?)
b.) you're not fully extending the rafters. If you did, you could open the door.
(On ours there is an indicator that shows how far you can extend them so I know we have 4 (I think) clicks. I set the front for 4 and the back for 3 so the rain will run off and not puddle.)
So she took me through it step by step and now we are experienced at doing that, at least for this year.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 06-30-2015, 10:49 AM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
"Here's one that is obvious now but wasn't 2 years ago. Check side to side level BEFORE unhitching"
I finally learned that the hard way.
Also before unhitching make sure the sewer hoses will reach the ground dump pipe and the power cord will reach the post.
MICHAEL
Old 06-30-2015, 10:51 AM   #7
Hiho Silver's Avatar
2016 27' Flying Cloud
Overland Park , Kansas
I just learned about putting the awning in caravan position by watching the video on airstream.com
0 notches. Just deploy the rafter arms and let it roll up. Very quick
Hiho Silver is offline   Reply With Quote
Old 06-30-2015, 10:52 AM   #8
remphoto's Avatar
2015 16' Sport
Upper Sandusky , Ohio
Cheers,
John
Great thread! A thought on the dead battery -- perhaps the refrigerator fan came on with the hot weather?
remphoto is offline   Reply With Quote
Old 06-30-2015, 12:22 PM   #9
AStreamNerds's Avatar
2015 25' FB Flying Cloud
Manassas , Virginia
I knew something was wrong with the awning the first few times we used it but I knew I was doing it right because it was the EXACT way we were shown by our dealer. At a campground during the middle of the day the awning rolled up a little and I said to myself that there has to be something I am not doing right so I looked up online and for sure I was not pulling out on the top arms to lock them - I felt like such a dummy for a few minutes then all of a sudden I was a genius LOL
Our Website: https://airstreamnerds.com/
You Tube Channel "Airstream Nerds": https://www.youtube.com/airstreamnerds
Find Us on Facebook: https://www.facebook.com/AirstreamNerd/
AStreamNerds is offline   Reply With Quote
Old 06-30-2015, 12:37 PM   #10
Rich W's Avatar
I'm In , Kentucky
Patio mat
We stayed in Florida for a month this winder. It was our first long stay anywhere. We had to move several times and it was always just after a rain, so the tarp that I was using, covered with that green outdoor carpeting, was always really wet. The PO had left us a smaller tarp with an open weave, which I used on the street side by the power and water hookups.
The open weave tarp allowed the water to drain through it and would dry out pretty fast when placed in the sun. The brown tarp with green carpet took forever to dry because the tarp held all the rainwater. When it was raining the water always puddled by the door or on the path from the TV to the door.
After the first AS move I placed the open weave tarp in the front third of the trailer, by the door, and kept the brown tarp to the rear. The green carpet went on top and rainwater just went through that and the open weave tarp; no puddles.
For our next long trip I plan on getting the Aero-weave mat, a big one, and leave the brown tarp at home.
Aeroweave Breathable Outdoor Mat - Santa Fe, 7.5' x 20' - Prest-O-Fit 2-3031 - Patio Mats - Camping World
-Rich
Rich & Yvonne
Old 06-30-2015, 12:43 PM   #11
dznf0g's Avatar
Oswego , Illinois
On a long awning (mine is 21 or 22 feet) the 4 vs 3 notch won't drain all the water, due to sag in the middle of the fabric. However, 4 vs 2 will still let the door clear on the long awnings and drain completely. Learned that the hard way.
-Rich-
Old 06-30-2015, 12:44 PM   #12
John&Vicki's Avatar
1990 25' Excella
Sisters , Oregon
I had an Aha! moment with mats also. We have a nice open weave one that I found in the Classifieds here. I always used it under the awning and then we had visitors on an outing to a NFS campground and I had the thought to use it under the table and chairs setup for happy hour by the river. Very nice, made it really cozy. So now I've gone ahead and bought another one for under the awning. And you're right - open weave is the only way to go.
Cheers,
John
John Audette
Old 06-30-2015, 12:49 PM   #13
Sbb
begorragirl
Sbb's Avatar
2017 25' Flying Cloud
Denville , New Jersey
I have two aha, make sure before you open to dump that both grey and black tanks are indeed closed all the way,and when folding up awning, dont get too excited you followed the video correctly and let go of tail and have it wrapped tight into the roll.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
Sbb is offline   Reply With Quote
Old 06-30-2015, 12:50 PM   #14
RangerJay's Avatar
2002 19' Bambi
Northwestern Ontario , - on the backside of the map and just above the big green spot
Images: 44
For multiple AHA moments the value of WD40 cannot be overstated ..... the door latch, door hinges, leveling jacks, sewage valves, piano hinges on the cabinet doors, Hensley stinger (every time you hook up), polishing the stone guards, preventing corrosion on battery terminals ...... and on ..... and on ...... and on ......
Don't leave home without it ......
Jay
Bambi - 2002 (The Toaster)
Pathfinder - 2009 (The Buggy)
"I'm not young enough to know everything ....."
(Oscar Wilde)
RangerJay is offline   Reply With Quote
Old 07-01-2015, 11:39 AM   #15
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Use the electric tongue jack to lift the truck and trailer so the weight bars come off by hand. Never use the cheater/lever.
If you use an Equal-i-zer hitch, store the weight bars in the L-brackets so you never have to lift them. Just slide them back.
On the Classics with the belly pan water hookup compartment, route the hoses through the bottom of the compartment and close the door.
Use a pool noodle on the awning arm to keep from walking into it, or to at least make it hurt less when you do walk into the awing arm.
Make reservations 6 months to 1 year ahead so you get to go camping instead of sitting home.
When winterizing, don't forget the outside faucet and toilet valve.
Before driving away, make sure you have everything from the campsite loaded, all compartments closed, the sewer cap is on, the TV antenna is down, the umbilical cord is connected, tow mirrors are extended, and the truck is in tow/haul mode.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 07-01-2015, 12:07 PM   #16
Rich W's Avatar
I'm In , Kentucky
I just added a pool noodle to my shopping list. I think I have a large dent in my awning arm near the door that pretty much matches the shape of my head. (No, not the other way around, my head's too hard, just ask my wife.) What a great idea. How about the guy wire/ropes for the screened enclosure over the picnic table? I was thinking of some kind of clip-on sleeve.
For Florida snow birding at least, it's possible to find places in the middle of the state as late as mid-December. The further south or closer to the coast, the tougher it is. You may have to move from spot to spot and you may not get the best spot, but you'll be warm . We made reservations at Christmas and spent a month, could have stayed longer. The more popular sites are definitely harder to get, some reservations are 2 years out.
Before driving away, make sure the TV antenna is down, the umbilical cord is connected....
We have an "antenna monkey", a visual control. It's a stuffed monkey with Velcro on its hands and feet. We put him on the antenna crank to remind us to crank it down. (Technical term is 'visual control'.)
I need to figure out something for the umbilical cord. I forget sometimes, until the first time I have to stop and have a difficult time with it. I need something to put in the TV cab to remind me.
-Rich
Rich & Yvonne
Old 07-01-2015, 12:23 PM   #17
"Cloudsplitter"
Maybe some here could transfer this to Stream'n.
....honey why isn't it coming off the Trailer?
Old 07-01-2015, 12:36 PM   #18
m.hony's Avatar
2013 30' Classic
Antenna monkey?
That's just funny!
To remember the umbilical, do a pre-trip/walk-around before you drive away- checking all lights- running, marker, clearance,stop, tail, brake, turn signal, reverse, and license plate. Also, check the trailer brakes.
I still walk around the rig checking everything again even after I am sure everything is done.
Another thing- make sure the steps are folded up.
TAC #MS-10
Airforums #70955
Old 07-01-2015, 01:35 PM   #19
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
I rarely need a 50' water hose. I made two from it with a knife and some fittings, a 15 and a 35.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
Alphonse is offline   Reply With Quote
Old 07-01-2015, 01:55 PM   #20
Mantua , Ohio
Always limit coffee intake and use the bathroom before leaving. Unless of course you want to stop in a couple hours. When we were mc touring we drank coffee to force ourselves to have a rest stop as to not get too fatigued.
What did you get for your Motorhome today? Keyair Classic Motorhomes 1472 02-26-2024 02:48 PM
What did you do today? Trex Off Topic Forum 140 10-04-2017 03:40 PM
What did you learn.... silverlabs 2009-2015 Flying Cloud 25 07-05-2014 10:02 AM
Where did you drive your Classic Airstream Motorhome today? crazeevw Classic Motorhomes 29 04-06-2012 01:32 PM
Today's today, You know what that means? codybear Off Topic Forum 20 11-08-2006 11:31 PM
