Old 12-06-2014, 02:58 PM   #15
Francisco , Indiana
Slide
We have a slide on our 30' Classic. No problems what so ever.
We love it, I know it is only 20" but we have two recliners and still have a table to set at.
No wet spots, no dust problems, tow with a Dodge 2500 so no weigh issues.
Had to go back to regular trailer.
Hickory
hickory is offline   Reply With Quote
Old 12-06-2014, 10:23 PM   #16
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
I suspect there are units that have problems but mine has NOT had an issue during it's 12 years of service. Preventative maintenance is limited to lubricating the tracks and gears annually, wiping the rubber gasket with protectant (303) frequently, and not leaving the slide awning extended during gales. The 20" extension adds about 14 square feet of space which is a significant add to living space in a 28' footer.
We have camped in every situation from boondocking to RV resorts. Our slide has never been restricted from opening due to space limitations by trees or intrusion into an adjoining site including parks where slides are restricted. We do use our dinette at rest stops as it does not restrict access to or use of the interior spaces.
If you are level enough to operate your refrigerator, you can use your slide too, so I wonder what was meant by the earlier comment. I have encountered quite a few Airstream Slide-outs in my journeys and have yet to meet an owner displeased with their unit. A common question in those discussions is, "Have you had a problem?" and the reply has been negative.
I was told Airstream quit production due to low sales volume as the number of slides produced was ~84 units for all models and years which is less than a month at current manufacturing levels.
My experience with owning a slide mimics Pappy19.
SeeMore is offline   Reply With Quote
Old 12-07-2014, 10:33 AM   #17
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Advantages or disadvantages of an AS slide out
I've had no issue with my slide either. One of the easiest ways to mess up a slide is to extend it or retract it when the stabilizer jacks are retracted. This causes the frame to have excessive torque on it. Dealers were notorious for units on the lot to extend those slide outs without the jacks down.
The basic issue that hurt the sales of Airstream slides were the heavy hitch weights of the slides and the cost that they added to an already expensive trailer. My net cargo capacity of my 30' Classic is 660 lbs when traveling with full water. That pretty much puts me at the published gross of my trailer which is 9,100 lbs. With that in mind I usually only have one trip a year where I will tow with full water. I also have a 3/4 ton van that can handle tow trailers up to 9,900 lbs. I also had to upgrade to a class V hitch that is rated for 1,400 lbs of weight.
I do love the slide and have no regrets. I don't think we have any slide users on the forum who have posted significant slide concerns. Airstream did their homework on the slide and produced one of the best slide out units of any manufacturer.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 12-07-2014, 10:52 AM   #18
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
If I recall, my one and only cat scale ticket reflected a 1476 pound tongue weight! Whopper!
Old 12-07-2014, 11:51 PM   #19
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
All Is Not Lost
If weight is a significant issue, look for a 28' Safari slide-out unit. The lighter weight cabinets, laminate counter tops, and shorter overall length of mine causes it to weight in at 6,760 lbs with a tongue weight of 980. The GVW rating is 8,600 so after adding 560 lbs for full tanks (gas & water) I still have 1,280 of cargo capacity.
Old 12-08-2014, 12:11 AM   #20
jcanavera's Avatar
Fenton , Missouri
Images: 143
Airstream addressed the weight issues with the later years. I think the frames could carry another 1,000 lbs over my 2003.
Jack Canavera
STL Mo.
AIR #56
Old 12-08-2014, 03:59 AM   #21
carver 1's Avatar
2011 30' Classic
2007 25' International CCD
1993 32' Excella
Largo , Florida
Images: 30
Thank you one and all for your responses to my question about the efficacy of the AS slide out. I'm convinced, based on the response. Now all that has to be accomplished is to work out the right deal on the one I'm looking at.
>>ron<<
2015 GMC Denali 2500, 4x4, Duramax diesel, Topper, Pro Pride 3 P, Sendel 16" with Michelin LTs, one Yellow Labrador Retriever (AS security)
carver 1 is offline   Reply With Quote
Old 12-08-2014, 10:31 PM   #22
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
carver 1, good luck in your search. From what I have been told over the years, there were approximately 84 total slides built spread fairly evenly across the 28 (all Safari models), 30, and 34 lengths. Finding one may take patience.
Advantages and disadvantages CMSmith Our Community 10 02-06-2012 12:03 PM
WBCCI Membership Advantages? rebelstand WBCCI Forum 33 10-10-2011 12:20 PM
Advantages / Disadvantages of Astrodomes Grand Master Roof Vents, Skylights & Fans 3 04-24-2009 06:53 AM
Advantages and disadvantages of 28 vs. 34 Scott Hopkin Airstream Trailer Forums 11 02-25-2005 10:32 AM
Disadvantages of polishing... InsideOut Cleaning, Stripping & Polishing 13 09-03-2003 06:29 AM
