Old 06-27-2019, 04:21 AM   #1
AlanMcD's Avatar
Cincinnati , Ohio
AC Easy Start On 110V Wall Outlet
I know the easy start will allow you to run the AC on a 2K generator but will it also allow you to run it on a regular 110V, 15 amp wall outlet? I had the Easy Starts installed on both my AC's at JC this past Winter and I am camping this weekend at a campground that only has 110 electric and it's going to be 90+ degrees! Oh, and the campground doesn't allow generators.
-Alan
Cincinnati, OH
Blog: http://alanandcarie-airstream.blogspot.com/
AlanMcD is offline   Reply With Quote
Old 06-27-2019, 04:55 AM   #2
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Unless it's really old, a regular 110 outlet should be 20 amp. that works fine with EasyStart.
2019 Ford Expedition Platinum
Old 06-27-2019, 06:04 AM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Yes it will work fine.
Dept of “OverKill”
Old 06-27-2019, 04:47 PM   #4
2007 27' International CCD FB
San Diego , California
Yup. Works great actually if one is cautious to keep other loads off. A significant one being the converter charger.
I believe on most AS's, one will have to turn off the 120V breaker manually in the trailer, that serves the converter.
In my '07 vintage 27FB, at the power center, it is breaker circuit #2. You can see the sticker below the breakers which lists "Cir.2 20A Converter-Desk Bedroom Recepts".
Counting from the left, this would be the 3rd breaker position, as the very first breaker position is actually the "30A Main" input.
I largely leave my converter charger off these days as I have significant solar to do all the charging. So I added the red switch to only turn off the converter.
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
Tongue Mount Honda eu2200i - Rear Hitch - Underbelly Storage - Blizzard NXT w/ EasyStart - 3" Lift - 6" Fan Controller
pteck is offline   Reply With Quote
Soft Start - Easy Start - Smart Start..? JConsroe Generators & Solar Power 13 06-16-2017 07:36 AM
Electrical - Adding a 110V outlet from Battery sbair Batteries, Univolts, Converters & Inverters 2 07-21-2011 07:14 PM
How EASY to break into Airstream? TOO EASY Foiled Again Doors & Locks 20 04-19-2010 11:14 AM
Adding an Exterior 110v Outlet to my Sovereign mello mike Electrical - Systems, Generators, Batteries & Solar 19 04-09-2010 11:21 AM
Microwave 110v power outlet location? SnoSheriff Stoves, Ovens & Microwaves 1 07-24-2009 12:46 PM
