Old 06-06-2015, 02:32 PM   #29
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We ended up bypassing the 2012 Dodge Ram factory brake controller as it was completely incompatible with our Titan BrakeRite II SD hydraulic brake controller. We installed the Tuson DirecLink NE brake controller and all was well.
We did an isolation of the truck controller so it thinks all is well as it never "sees" the trailer, thus no error codes are thrown.
Old 06-06-2015, 03:04 PM   #30
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
Originally Posted by BoldAdventure View Post
I would of at least pulled the truck and AS forward some and applied the trailer brake manually to see if it was engaging.
I'm not sure how common this is, but our 2005 F350 will not activate the trailer brakes at slow speeds. I think it might be less than 10 mph, but it's quite a while since I looked into it so I'm not sure now. The first time I hooked it up to our trailer I spent a long time trying to figure out why the brakes wouldn't activate as a drove down our driveway. I believe Ford did this to prevent the jerking you sometimes get from the trailer brakes when creeping along in slow traffic.
I know that's not Hans627's problem, but something to keep in mind for others if the brakes don't seem to be working at slow speeds.
Grant Davidson
Milton, ON
1946 Spartan Manor
1954 Va-Ka-Shun-Ette
1964 Overlander
1965 Avion C-10 Truck Camper
1974 Sovereign
2005 F-350 SRW 4x4 crew cab long box
TAC ON-5
DavidsonOverlander is online now   Reply With Quote
Old 06-06-2015, 03:19 PM   #31
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
Good luck with getting the brakes to work.
While disappointing, I've heard of much worse First Day adventures. Several about awning coming undone on the interstate. Wrecks on the freeway after the first camping trip. Driving away with the electrical connected.
These things happen - on the first day and everyday thereafter. All you can do is learn from your adventures, and learn from other people's adventures.
Good luck on your next adventure!
RAH is offline   Reply With Quote
Old 06-06-2015, 06:06 PM   #32
2005 28' Safari
Saint Joseph , Michigan
Same thing happened to us and just took it easy.
[QUOTE=AWCHIEF;1632962]Heck I would of hooked up and headed on home. Slow and easy.
Same thing happened to us and just took it easy on the way home. We have years of trailer delivery behind us and this happens a lot. As long as the lights work, don't get close to anything, look way ahead for traffic and stop lights and you'll be fine. Once pulled a SOB 30+ feet fifth wheel over the Sierras South Lake Tahoe to Sacramento w/o trailer brakes. No problems.
TruckerFritz is offline   Reply With Quote
Old 06-06-2015, 06:18 PM   #33
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Except legality. Or lack thereof…
If the OP or anyone else wants to violate the law and tow a 3000-pound-plus trailer with no brakes, that's up to them. But it's irresponsible at best, and criminally negligent at worst, to actually advise someone to break the law.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 06-06-2015, 06:19 PM   #34
Senior Member
sheriff1's Avatar
2014 30' Flying Cloud
Sparks , Nevada
I would have hooked on and brought it home myself, I've never been known for my common sense!
The OP is not an experienced tower and had less than open road to work with . Congratulations on his EXCELLENT decision to go back when things are corrected!
2015 F350 CC 4X4 6.7 Diesel
2010 27FB Silver Cloud "The Silver Spoon"
sheriff1 is offline   Reply With Quote
Old 06-06-2015, 08:43 PM   #35
1977 25' Tradewind
Cibolo , Texas
I had the same problems with my AS when I bought a new 1993 F-250. I took the truck & AS to a trailer sales shop & they changed the 7 way plug on the AS and it worked just fine. Since then I have bought several new truck and the lights & breaks works just fine without any further changed.
GailMac is offline   Reply With Quote
Old 06-06-2015, 08:57 PM   #36
Manheim , Pennsylvania
My 2009 Dodge Ram 1500 does not have an intergrated brake controller. I just went to walmart and bought a Reliance brand brake controller. I had to find a special chrylser/dodge pigtail adapter to connect the wires, but it works fine. I mounted it under the steering wheel down low between my kness on the dash panel. I usually have to play with the variable brake setting to get it to my liking. Sorry to hear you are having trouble, I was wondering how you made out.
Jukeboxfun is offline   Reply With Quote
Doran=Disappointing Silver Otter Tires 55 10-18-2012 02:43 PM
Pgh RV show - disappointing! wannaroam Our Community 5 01-12-2007 07:35 AM
Disappointing 22' CCD Problems kshogan 2002 - 2005 International 15 11-01-2006 10:36 PM
