Old 07-20-2012, 11:34 AM   #1
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
A/C in a 30 fly cloud or international?
Have a good buy set up on a Flying Cloud 30 and also a International Serenity 30. One has the two A/Cs the other only one. Can any one tell me if the one unit will do the job nicely. We will be RV ing in South Texas and it can get real hot.
Howard
Howard L. is offline   Reply With Quote
Old 07-20-2012, 11:39 AM   #2
murreywalker's Avatar
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson , Missouri
You'll probably be happier with the one that has two units.
2013 25 FC FB (Twin)
2013 Suburban 2500
http://www.pbase.com/murreywalker
2011 23 FC FB
murreywalker is offline   Reply With Quote
Old 07-20-2012, 11:49 AM   #3
ASwifey's Avatar
2010 30' Flying Cloud
Bakersfield , California
We have the 30 foot Flying Cloud. If you turn the AC on in the morning before it gets too hot it does ok, but once it gets hot inside the trailer it just doesnt cool it down very well. We have just the one AC unit.
California Streamers Fall 2016 Rally ~ Kernville 10 ~
2016 Pismo Rally
Southern California Airstreamers Just ask to join!
I do yoga to relieve stress, just kidding I drink wine in yoga pants
ASwifey is offline   Reply With Quote
Old 07-20-2012, 12:01 PM   #4
Skater's Avatar
1995 30' Excella
Bowie , Maryland
That's pretty much how ours is on those unbelievably hot days. We have one AC.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 07-20-2012, 12:17 PM   #5
Howard L.'s Avatar
San Antonio , Texas
Thanks you three. The Flying Cloud has the two units. It also has the recliners which we like (just the two of us, plus two spaniels--the couch in the international would belong to the spaniels--the recliners will be ours.)
Howard
Old 07-20-2012, 12:44 PM   #6
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Yep, my vote is for two ACs. The recliners sound like another plus.
Vaughan
Old 07-20-2012, 12:52 PM   #7
Enthusiastic New AS'r
3campers's Avatar
1985 31' Limited
Glenville , New York
Images: 18
Two sounds better than one but I have a 31 Limited with one and it works just fine.
1985 31' Limited
2003 GMC Sierra HD SLT 4x4
3campers is offline   Reply With Quote
Old 07-20-2012, 12:59 PM   #8
Skater's Avatar
1995 30' Excella
Bowie , Maryland
A lot of it depends on the temperature. 80 degrees outside? No problem. 90? It'll probably catch up that evening. 100? Forget about it. The problem is biggest the first day of camping, of course, since the camper has had the time to heat up to the ambient temperature outside, or more, while you were on the road. After that day, even if it can't keep it at your desired temperature, it's at least removing humidity, which helps a lot.
(I don't have extensive experience with our AC yet, so I'm just guessing at these numbers. We've actually had some pretty decent weather for camping and haven't had to use it that much.)
Old 07-20-2012, 01:38 PM   #9
SteveH's Avatar
Common Sense , Texas
We're also in South Texas, have a 31', and believe me, you NEED the two A/C's.
Old 07-20-2012, 02:06 PM   #10
tpi
Trabuco Canyon , California
In Texas if you can get two AC units, go for it. I had one AC in both my 25' Airstream and 15K btu in my new 24' class C motorhome. Both huff and puff and struggle with the initial cooldown. They both also take extra measures to make them adequate in very hot weather (shading windows, vents etc.).
I see no downside to the two units except for the 50 amp requirement to run both. Use both for cooldown or when its very hot outside. Use one when that is all needed. Best of all worlds.
tpi is offline   Reply With Quote
Old 07-20-2012, 03:47 PM   #11
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
If I was based where you are or did a lot of summer travel in that area, I'd have two units. It's been pretty ugly this year in my neck of the woods and we've been hitting 100+ temps since late in June. Even with my 15K unit on my Classic I'd be hesitant to go out in this stuff unless I knew I was under a tree most of the time. Right now our forcast for next week is 100+ every day. We are hearing as much as 108-109 on Tuesday. I heading out in a couple of weeks and I'm high tailing it out to the far north woods.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 07-20-2012, 03:54 PM   #12
SteveH's Avatar
Yes, when we were in Sedalia a few weeks ago, it was around 100 every day, and we had only 30 amp hookup, so only one A/C unit. It was miserable in the trailer until about 9 PM.
Should I mention that all the International and Region officers that got there a month early got all the 50 amp hookups?
Old 07-20-2012, 03:57 PM   #13
1983 34' Excella
1967 24' Tradewind
Images: 32
It was 108 a few minutes ago here in Little Rock. A couple of weeks ago, it was 108 in my yard in the shade and 95% humidity.
I wish I had a second AC.
Vaughan
Old 07-20-2012, 05:21 PM   #14
jcanavera's Avatar
Fenton , Missouri
Images: 143
Just curious did your trailer come with the 15K unit or was it the 13.5K? I know when ours was built the standard was 13.5 K and 15K was an upgrade. I had a 13.5 K unit in my 27' Safari and I was out in 104 degree weather in full sun. We rose as high as 88 in ours. Have never experienced anything more that the mid 90's in my Classic and my 15K unit seems to work fine. I'm not sure where it would be though once you would get too much over 100.
Jack
Jack Canavera
STL Mo.
AIR #56
