Old 11-19-2014, 10:13 AM   #1
1973 31' Sovereign
Boerne , Texas
Why So Many Keys?
Making my way down the checklist and now it's come to keys. We have 4 keys. None of them fit the storage compartment. Can't find the lock code to order a new key. If we have to call a locksmith to have a new tumbler put in, I am seriously considering having all the outer compartments keyed the same. And here's the rub... I have keys with apparently no locks to match. :/
Gwendolyn
campindaisy is offline   Reply With Quote
Old 11-19-2014, 10:18 AM   #2
terryV's Avatar
2002 31' Classic
Monroe , Iowa
Personally, I think that would be a great idea. One for the door, and one more for everything else.
terryV is offline   Reply With Quote
Old 11-19-2014, 10:40 AM   #3
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Good question but call a dealer and he can tell you what key(s) you need.
Larry
lsbrodsky is offline   Reply With Quote
Old 11-19-2014, 10:54 AM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
My Bambi II came with 8 different keys. I am happy that my Safari only requires 4. It is all a matter of perspective.
MICHAEL
Old 11-19-2014, 11:06 AM   #5
1973 31' Sovereign
Boerne , Texas
Eight keys? How many locks can one little Bambi have?
Gwendolyn
Old 11-19-2014, 11:53 AM   #6
richinny's Avatar
2011 34' Classic
1&2 - door lock
3 - battery box
4 - water door
5 - coupler lock
6 - storage door
7 - ?
8 - ?
Ricky
Old 11-19-2014, 11:59 AM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
All doors keyed alike is such a simple idea I wonder why Airstream didn't think of it? Except that they probably have all these locks, with keys attached, in one big bin, without sorting them, and they just install whichever one they grab first.
Since it would take a few minutes longer to select an entire set of locks that all take the same key, maybe Airstream could offer "keyed alike" as an extra-price option, but cheaper than the customer ordering a whole new set of locks after the fact?
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-19-2014, 01:11 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
The problem, both for the factory and for purchasers looking to retrofit, is that the various locks on Airstreams are specific to the RV industry. While a locksmith can rekey them, it is generally not possible to replace them with cores that will accept a single blank.
One of the main problems is that almost all the lock cylinders have a shutter to keep dust and rain out of the keyway. This isn't a standard feature on general-purpose commercial or industrial lock cylinders.
I was able to lower my key count by 1 by retrofitting a battery-compartment lock to the water door. I still need 4 keys.
campindaisy, it is possible that the lock is just stuck from disuse, corrosion, or dirt. You can try to clean it with compressed air or solvent, and then use some graphite to lubricate it. Don't use oil, it will create problems over the long term.
Old 11-19-2014, 01:23 PM   #9
I've had good results using WD40 or gun oil (but not both at once) when I didn't have any graphite laying around. But graphite is better.
WBCCI #1105
TAC LA-4
Old 11-19-2014, 02:34 PM   #10
AWCHIEF's Avatar
Images: 33
Originally Posted by richinny View Post
1&2 - door lock
3 - battery box
4 - water door
5 - coupler lock
6 - storage door
7 - ?
8 - ?
Close but no cigar.
1. Door lock
2. Dead bolt
3. Mystery key
4. Water heater door
5. Storage compartment by rear bumper
6. Battery door
7. Hasp and lock attached to inside of sealed and non opening rear window, that was a strange one.
8. Coupler lock
There was also a ring of 10 keys in the paperwork folder, never have figured what they were for.
MICHAEL
Old 11-19-2014, 03:04 PM   #11
bigjohnn's Avatar
los lunas , New Mexico
Keys
If there all keyed the same they get in front door and all compartments
bigjohnn is offline   Reply With Quote
Old 11-19-2014, 10:44 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
In our AS, if you raise the bed you can crawl into the storage area. Once there you can unscrew the nut holding the latch, remove the latch and open the storage door.
It is simple to take the tumbler out and bring to a Locksmith for retrofit.
Or, they can make a key to fit it...
Peace and Blessings..
Channing
WBCCI# 30676
Old 11-20-2014, 07:38 AM   #13
AWCHIEF's Avatar
Images: 33
Originally Posted by AWCHIEF View Post
Close but no cigar.
1. Door lock
2. Dead bolt
3. Mystery key
6. Battery door
8. Coupler lock
Correction, #4 was for the power/utility compartment. No lock on the water heater door.
MICHAEL
Old 11-20-2014, 08:32 AM   #14
1973 31' Sovereign
Boerne , Texas
Thanks for the tips everyone. We did try WD-40 and Carborator cleaner. DH took one apart completely with no luck. None of our mystery keys fit.
After figuring that it will be about $200 for a complete new set of keys (knowing that I have to pay the locksmith to come to my location), we decided to put that off for now. Eventually, we will rekey them all to have one front door key, one deadbolt, and one for everything else.
Gwendolyn
1973 Airstream Land Yacht Sovereign -- Many Many Many Upgrades!!! eBay Watch Airstreams on eBay 0 06-18-2013 06:30 PM
Keys how many different ones? perryg114 Exterior Storage Compartments & Access Doors 1 10-06-2011 10:45 PM
OT: How many trailers is too many? Amazing short video. SilvrSausage On The Road... 1 09-10-2008 04:44 PM
Why, Why, Why aviontt On The Road... 22 11-20-2003 07:41 PM
Just how many keys does it take for an AS...REALLY!? wahoonc Doors & Locks 6 11-15-2003 07:22 PM
