Old 07-27-2011, 08:38 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Where to find custom A/C vent?
I'm putting an air conditioner inside a cabinet in the rear of my Bambi II. I'll be using a casement window type a/c & will need to put a refrigerator type vent in the skin to vent the hot air. It needs to be about 9" wide by 15" tall. Does anyone have a suggestion on where to get an aluminum vent this size? It can be permanently attached to the rear & doesn't have to open. Any suggestions welcome!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 07-27-2011, 08:49 PM   #2
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
Check with an hvac materials supplier; they usually have various sizes of return air vents. They may be able to order one exactly the size you need.
1982 34' Limited
2000 Excursion V10 4x4
WBCCI #3321
TAC #GA-24
c_lewis77 is offline   Reply With Quote
Old 07-27-2011, 08:52 PM   #3
c_lewis77's Avatar
1982 34' Limited
Brunswick , Georgia
Images: 22
...you could also check with a local hvac contractor, they will also have access to standard and custom vent materials
1982 34' Limited
WBCCI #3321
TAC #GA-24
Old 07-27-2011, 08:55 PM   #4
Ottawa , ON
Becky,
Won't it take a small roof model?
Old 07-27-2011, 09:00 PM   #5
Becky B.'s Avatar
1964 17' Bambi II
Originally Posted by Aage View Post
Becky,
I think it would, but I'd rather not have an a/c on the roof of such a small trailer.
I'm not putting a furnace back in, so I'm putting the a/c in the cabinet where it used to be. I've already got the a/c & would love to get it in soon so I can work outside if it's hot (which it has been for weeks now!)
Becky
1964 Bambi II
1988 Avion 32S
Old 07-27-2011, 09:29 PM   #6
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Would you not need 2 vents in the skin? Or are you going to continually exhaust conditioned air from the interior to cool the condenser? I think the most efficient way is to bring in outside air for condensing the refrigerant, so you'd need 2 vents or 1 big one you split for intake and exhaust.
— David
Old 07-27-2011, 09:44 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
I'll be venting the air intake from the floor. I'm doing it basically like the thread http://www.airforums.com/forums/f36/...-38289-38.html , but because I'm pressed for room, I don't have the space to add on to the back to vent up behind the license plate like he did (even tho I think its really slick). I'll need to back the unit right up to the rear wall & seal it off with weather stripping, etc. I've been surfing & haven't come up with a non-custom fit, but I haven't cut anything yet, so if I find something close, I might just order something non-custom. Thanks for the suggestions. I wonder if local sheet work shops are capable of making one?
Becky
1964 Bambi II
1988 Avion 32S
Old 07-27-2011, 09:57 PM   #8
Becky B.'s Avatar
1964 17' Bambi II
This one looks pretty good:
HVACQuick - Dayus DARH-FG Return Air Filter Grilles - LOUVER STYLE
Becky
1964 Bambi II
1988 Avion 32S
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
Is a stove vent really needed? BWH-Utah Stoves, Ovens & Microwaves 6 06-22-2011 03:44 PM
Fitting a Nicro vent to the existing Hehr vent Globie64 Roof Vents, Skylights & Fans 8 03-17-2011 02:35 PM
Replacing center roof vent in a '79 blickcd Roof Vents, Skylights & Fans 1 01-29-2011 04:58 PM
