Old 10-15-2014, 06:48 PM   #1
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
Where do I find "skin" sheet aluminum?
I'd like to find the proper matching aluminum skin from a mid to late 60s airstream to make a door where my water heater used to be in my 65 Caravel (going tankless). I'd like to match it closely to look the best in the fabrication. If I knew where a dead or totaled old trailer was, I'd like to go up and shear out a panel.
Anyone?
Jeepers! is offline   Reply With Quote
Old 10-15-2014, 07:30 PM   #2
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Google Aircraft Spruce & Specialty Co. then check their website for aluminum. What you need for a '60's Airstream is called 2024T3. For the shell you'll probably need .032 thickness.
Or check your local small aircraft repair shop. They might have some scraps the size you need.
Old 10-15-2014, 07:44 PM   #3
reinergirl's Avatar
Hollis , New Hampshire
You can order small pieces of 2024 (2x2 and 2x4) from Vintage Trailer Supply
reinergirl is offline   Reply With Quote
Old 10-15-2014, 09:13 PM   #4
Jeepers!'s Avatar
1965 17' Caravel
San Antonio , Texas
All good ideas, thanks.
In a perfect world I'd like to find a piece with a similar aged patina as my unpolished 65. A bright shiny new chunk of aluminum on a 49 year old body may be a bit garish. Somewhere there lies an old wrecked hulk I could just take some from...
Old 10-16-2014, 06:50 AM   #5
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
wipe the new piece down with Alumiprep, it will take the shine right off
Old 10-16-2014, 11:12 AM   #6
1978 31' Excella 500
Huntington Beach , California
Yes, Aircraft Spruce is a very good source. Pilot Supplies and Aircraft Parts from Aircraft Spruce
Jerry Ski is offline   Reply With Quote
"silver avion" avion C11 airstream "truck camper' "slide-in" aluminum eBay Watch Airstreams on eBay 0 09-14-2013 06:20 PM
Aluminum sheet thickness/type crispyboy Ribs, Skins & Rivets 2 05-29-2007 01:58 PM
Aluminum sheet as "wallpaper" mcostanzo Upholstery, Blinds, Walls & Interior Finishes 3 06-25-2003 09:30 PM
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 08:48 AM
