10-25-2009, 03:34 PM
1972 27' Overlander
Bonita
What is This For ???
Switch of some kind ? Located at top of the curbside compartment that contains the Univolt.
10-25-2009, 03:37 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
Looks like a light switch designed to come on when the door is opened. Reminds me of the one in the glove-box of my first car, a '56 Chevy.
Vaughan
10-25-2009, 03:40 PM
Corona
That is exactly what that switch is for.
10-25-2009, 04:02 PM
1972 27' Overlander
Bonita
I thought it was a light switch too but have not been able to locate the actual light it controls. The yellow wire dissapears into the wall adjacent to the switch.
10-25-2009, 04:28 PM
Princeton
, New Jersey
That looks like a home made addition.
Take a voltmeter and see if you have voltage on either or both of the wires at the switch. If you have voltage on both wires it is a switch to turn something on when the door id open. If you only have voltage on one wire it is a switch that turns something on when the door is closed.
Depending on which you find will determine where we go from there.
Most likely it is a switch to turn a light on, voltage on both wires when the door id open, and you have to find the light. The bulb may be blown.
I would suspect you will find the yellow wire is hot from the battery.
If neither wire has voltage on it someone may have disconnected the source upstream and you may never find it.
2004 Excursion 4x4
10-25-2009, 05:14 PM
1977 27' Overlander
Trotwood
Hummmm thats different. I have lites in compartments but they look like a maplite from a 36 Chevy. Little lever on the side that eccentrics the bulb in and out to make contact. Im supprised mine work after 33 yrs.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
10-25-2009, 05:23 PM
1972 27' Overlander
Bonita
May have to call in the previous owner (my neighbor). He is a retired electrical engineer as well. May be something he added many moons ago.
10-25-2009, 05:38 PM
Corona
The light socket was overhead in the access compartments.
10-25-2009, 06:19 PM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
some types of glove box lights have the bulb socket on the back of the button. it could also be an alarm switch.
Ricky
10-25-2009, 06:37 PM
1972 31' Sovereign
Lexington
We had those in our exterior hatches, all connected to little tiny light bulbs. No idea if any of them worked anymore as we disconnected them and stripped it all out as we disassembled the interior, and there was no power to the trailer anyway. We'll probably add something to some of the hatches as we rebuild, but maybe something we have to turn on ourselves? Not sure yet. Chris is going to be working on those details this winter with the electrical diagrams...
Kay
10-25-2009, 06:59 PM
1972 27' Overlander
Bonita
Just went and looked again (this is driving me crazy) and it appears that the bulb socket IS on the back of the switch. The first time I reached in and felt around behind the switch it felt too small to be a light socket. It is a light socket, but takes a much smaller type (anyone know what type)bulb than the 1141's found throughout the trailer. Thanks guys.
10-26-2009, 12:10 AM
2011 34' Classic
Westchester Cty.NY
, / Miami FL
#1891 .24A 14v
#1816 .33A 13v
either one should work. the 1816 should be brighter. they should be at many auto parts stores.
Ricky
02-03-2010, 08:00 PM
Louisville
, United States
That's actually an ejection button. Push it, and the driver of the TV ejects. Trust me, I'm retired Air Force!
SSChanger
'94 Excella 1000; '03 Silverado 2500HD
Louisville, Tennessee
02-03-2010, 08:13 PM
1972 25' Tradewind
Webb Lake
, Wisconsin
I would have said to look in the refrigerator to see if the lights come on.
02-03-2010, 09:38 PM
1978 28' Ambassador
Morada
whatever you do, never 'clip' the yellow wire! I learned that from McGuyver...
If there's no light inside, I agree, it might be an intruder alarm switch...or perhaps the switch indicates that the door is 'ajar' when you look at the master electrical panel inside the trailer...
Ray
Ray & Pat; Morada, CA
02-04-2010, 10:48 AM
1970 27' Overlander
ARLINGTON
, TEXAS
I have that same button and it controls the light in the battery compartment and one in the rear compartment over the bumper.
He is your friend, your partner, your defender, your dog. You are his life, his love, his leader. He will be yours, faithful and true, to the last beat of his heart. You owe it to him to be worthy of such devotion...
Taylor 1/20/96 - 11/28/08
