Old 08-25-2010, 02:57 PM   #1
coffeydelsol's Avatar
1986 25' Sovereign
Ocala , Florida
Water Heater Compartment Cover
Anyone know where I might find on that fits and 25' 86 Soverign? Got rushed backing into a space last weekend and caught it on a pole. Lucky we did not get into the body, only scrunched the cover a little. Any ideas?
coffeydelsol is offline   Reply With Quote
Old 08-25-2010, 04:17 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I believe you would require the Atwood aluminum water heater door. They are available from any Airstream dealer, part #670274-06.
The white ones are available everywhere for $20. The aluminum ones are no doubt somewhat higher.
Old 08-25-2010, 04:34 PM   #3
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
I'm going to be buying an Atwood water heater soon. I thought that the 'aluminum' doors were in color only and were painted steel. Jammer, thanks for the part number I'll check with a dealer.
SilverHoot is offline   Reply With Quote
Old 08-25-2010, 05:12 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
I'll check tonight but I'm pretty sure mine is actual aluminum. They may have used both kinds.
Old 08-25-2010, 05:14 PM   #5
SilverHoot's Avatar
1967 24' Tradewind
That's great if they are! Thanks
Old 08-25-2010, 05:18 PM   #6
fltlevel510's Avatar
2004 30' Classic Slideout
Between Here , And There
Water heater cover
If you really want to splurge, Roger Williams Airstream in Ft Worth sells a custom fabricated stainless steel replacement that really looks sharp. I think they sell for $85. Here is the contact info. Roger Williams Chrysler Dodge Jeep | New Chrysler, Dodge, Jeep dealership in Weatherford, TX 76086
fltlevel510 is offline   Reply With Quote
Old 08-25-2010, 07:10 PM   #7
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Last trip to the Factory Store I was told the "aluminum" doors are only available in 6 gallon. The doors they have are powder coated steel.
Old 08-26-2010, 03:01 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
I checked, mine is steel, painted gray to look kinda like aluminium.
Lost Water Heater Cover FischerRA Water Heaters, Filters & Pumps 0 09-22-2009 03:52 PM
Water Heater cover? frscott Exterior Storage Compartments & Access Doors 4 07-17-2009 04:17 PM
Vent Cover for water heater slk Water Heaters, Filters & Pumps 0 07-06-2009 04:08 PM
Inside hot water heater cover davidz71 Water Heaters, Filters & Pumps 12 03-24-2008 08:11 PM
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 01:30 PM
