I have a 74' Tradewind Land Yacht with a locked water fill door. No keys. Anyone out there have any ideas how to get into it without breaking or calling a locksmith?
Thanks for the info. Good website I have not seen yet. My first day as an Airforum member has been great. Solved several problems in less than 12 hours.
You guys/gals are the best.
Seeflash, I'm having a similar search for a '73 Sovereign. But I'm also trying to figure out how to reinstall a missing water pump under my oven with the Univolt. Any chance yours is there? Love to see a pic if it is.
(posted this reply in your gallery, but wanted to do it here as well)
Ok, that's exactly the image I've been looking for.
I have to ask though, why you chose to mount the pump with the water fittings at the far back side. Wouldn't that make it difficult to maintain if there was a loose fitting, etc.?
The view of the water intake outlet and air hose, etc. is perfect for my needs as well. Helps so much to see how you've routed things. My Univolt looks like it might be larger than your power supply there, but the idea of removing the stove unit to ease the work on this area has inspired me.
If it fits, AND turns, then pull on the small lip of the door to open it. If the key does not turn, you've got other problems, like wrong key. If it's like my '72 key, it's a double-sided key ("teeth" on both sides).
I bought the same key for my 75 TW and had the same (does not turn) problem. I took it to a key shop and they cleaned it up a little, but it still does not work. The key I bought for the fridge & battery doors works fine. The blank for the main door also fit after it was cut.
A lot of RV's use the same keys and locks for the various little doors. Do you have a friend with an RV—his keys may work. One other lesson is not to leave really expensive things in those compartments.
