Old 06-16-2012, 08:02 AM   #1
1988 25' Excella
Trumbull , Connecticut
Stainless steel water heater door latch?
Hello all. Has anyone ever found a source for the spring latch that holds the water heater door closed? If so please post it. THe Zinc coated ones rust and they are the only one's I've found for replacements.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 06-16-2012, 09:00 AM   #2
Silver Goose's Avatar
2008 27' Classic FB
Burkburnett , Texas
Try a search for Replacement Water Heater Door Latch #00225
The one I have appears to be powder coated and is black. The ones I've seen mostly seem to be the bright zinc coated ones you mentioned. These appear black in the photos, but they don't give any details. I think I've seen them from time to time when I've been browsing the parts stores.
AIR 47751
Air Safe Hitch, Reese Dual Cam 800#, Centramatics
Silver Goose is offline   Reply With Quote
Old 06-16-2012, 09:13 AM   #3
That part is called a "cam lock".
They are available in black metal, silver metal and white plastic.
Old 06-16-2012, 09:20 AM   #4
Yes, the silver ones rust after 10 or 15 years.
So.................
So do cars, that cost a lot more money.
Not too many things last forever.
Cam locks are real cheap.
Old 06-16-2012, 10:05 AM   #5
Wayward's Avatar
Cary , North Carolina
just plastic
It is a Camco latch although they do get called "CamLoc", which is a similar but different type of fastener readily available in stainless.
They do get rusty fast. I never was able to find a Camco in stainless. The plastic ones still have a steel spring but the handle is plastic. It does look a little thicker.
http://www.amazon.com/gp/product/B00...d_i=B0006JLVFI
2006 Safari SE FB
2000 F150 4.2L
2011 F250 6.2L
Broadway, NC
