Old 03-11-2015, 09:07 PM   #29
TahoeStream'n
subfan1's Avatar
2012 20' Flying Cloud
La Habra , California
Yes I did and yes I had to enlarge the opening. I used shears and then used clear coat spray on the edges. The new door has a key lock now and perhaps the box is made correctly as well so you won't have to cut.
I called the factory and mentioned that the shower was too big for the opening and there was no lock. Maybe they fixed the size, because the lock is there now.
subfan1 is offline   Reply With Quote
Old 03-12-2015, 07:52 AM   #30
dznf0g's Avatar
Oswego , Illinois
Originally Posted by Aage View Post
I remember seeing a paragraph in the installation manual for my new furnace strongly warning against using those screens. I can't recall if they mentioned why, and of course, the book is well-buried in the trailer, under several feet of snow.
Upon remembering this, I had a closer look at the ad for this that you posted, and I realized that it was not Suburban's suggestion that we buy those screens, but rather PPL's.
I would not use the furnace with them on during the heating season. Suggest checking with Suburban/Atwood if you want more information.
This depends on the screen design, IMO. If it is just a flat screen which is the same diameter at the furnace exhaust....I would stay away, due to restriction of flow. If, however, it is a domed screen, it has more open vented area to compensate for the wire restriction, and is OK....again, IMO.
-Rich-
Old 03-12-2015, 07:54 AM   #31
2015 25' FB Flying Cloud
Georgetown , Texas
Thanks, Subfan. I'll phone Airstream before I order. If I have to cut, it would be my luck to screw something up.....a big deal on those aluminum panels.
GLovedahl is offline   Reply With Quote
Old 03-12-2015, 09:09 AM   #32
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We installed the Airstream stainless steel potable water access door. It came with a key different from the usual CH751.
Old 03-14-2015, 03:04 PM   #33
Airlovr's Avatar
Very cool!!!!
Airlovr is offline   Reply With Quote
Old 03-15-2015, 09:25 AM   #34
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
...and here's the newest stainless steel option....I know it'll get scratched up, but even so, will look better than the pewter gray paint that also gets plenty ugly. Be advised, if you've never used stainless steel rivets, it takes a LOT more muscle. I suppose you could use VHB tape instead, but I did 8 rivets so I can "Live Riveted."
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-15-2015, 10:37 AM   #35
2007 22' International CCD
Nicely done. I'd go with rivets as well. Tape makes me nervous.
KE4GNK/AE
Old 04-13-2015, 03:47 PM   #36
2012 27' FB International
Victor , New York
Has anyone seen or had any experience with these stainless steel appliqués from the Airstream Store, which can cover the furnace, water heater, and water fill doors? I am trying to imagine how they would look and how they're applied.
https://store.airstream.com/product/...-furnace-door/
Meddle is offline   Reply With Quote
Old 04-20-2015, 06:39 PM   #37
Gazoo!
1963 19' Globetrotter
Denver , Colorado
I'm looking to replace my furnace, HW heater, Refrig vents and stove vents as they are galvanized panels. Is there a place to purchase these items in SS or Alum?
Thanks!
Sweneau is offline   Reply With Quote
Old 04-21-2015, 09:17 AM   #38
switz's Avatar
2014 31' Classic
Images: 8
Check the Airstream store. They have many of the items you expressed an interest in acquiring. I would give them a call to see if the current pieces would work on your vintage trailer. Lube the credit card as they are really "proud" of these accessories.
