Old 08-09-2012, 09:15 AM   #1
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
side compartment slide out tray
A while back somneone posted a couple of pics of an outside compartment that had a slide out drawer built into it. I thought I saved the thread but have since lost it... anyone have this book marked? Thankjs a bunch!
Barry
goshawks00 is offline   Reply With Quote
Old 08-09-2012, 09:44 AM   #2
Taylormade's Avatar
1978 31' Sovereign
did it slide out from one of the storage hatches or underneath from the belly pan?
Taylormade is offline   Reply With Quote
Old 08-09-2012, 09:52 AM   #3
Kevin245's Avatar
Could you be referring to this one in the MoHo forum?
http://www.airforums.com/forums/f311...bin-92137.html
Eleanor Roosevelt
Old 08-09-2012, 11:05 AM   #4
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
This one was a slide out that came out of a storage compartment on the side. It looked like a drawer with sliders attached. It was a cool idea and one I'm working on , just trying to figure out the slider attachment.
There a pic of the drawer..
Name:	IMG_2534 (Medium).JPG
Old 01-16-2013, 12:36 PM   #5
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
Nice work on your drawer. I'm thinking about doing something similar with the rear compartment on our AS. The rear ones are a wider and deeper so I'm thinking about doing something with a steel slider and a plywood deck. I have a sliding deck in the back of my pickup so that's my inspiration.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 01-16-2013, 02:44 PM   #6
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
I finished up drawer with tracks on the side to slide out. Works great and it's surprising how much 'stuff' can be arranged on it.
Sorry I have somehow lost the pictures of it, but will try to find them later.
Barry & Karen
Old 01-17-2013, 07:58 AM   #7
retired USA/USAF
2001 30' Excella
Thanks Barry,
Pix would be great. The rear compartment opens downward so there is a lip at the bottom probably around 3" or so. I would need to build up a frame on the inside to mount the slides. Of course in doing this I loose some headspace. That would be the deciding factor. I keep a lot of "STUFF" in milkcrates. They are a nice size, readily available and fit. As I lose headspace they may no longer fit. So may need to re-think things a bit.
Roger in NJ
TAC - NJ 18
Old 01-17-2013, 10:50 AM   #8
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
Your crate size will be determined by the measurement of you opening minus the thickness of your floor of your drawer. My actual AS door framing is 9-1/2" h -21" wide. My draw is 5-1/2"" high / 20" wide/30" deep. When hanging the glides I left 1/2" clearance all around.
Name:	IMG_2578 (Medium).JPG
ID:	176899   Click image for larger version
Name:	IMG_2580 (Medium).JPG
Name:	IMG_2581 (Medium).JPG
ID:	176901   Click image for larger version
Name:	IMG_2583 (Medium).JPG
Old 01-17-2013, 01:14 PM   #9
retired USA/USAF
2001 30' Excella
Thanks Accipiter gentillis, you have given me some ideas to ponder. This just might be my up and coming project. I may have to go to bread trays instead of milk crates though.
Roger in NJ
TAC - NJ 18
Old 01-17-2013, 01:28 PM   #10
goshawks00's Avatar
1966 22' Safari
Saline , Michigan
There are several types of milk cartons available, maybe you could look into shortening the height of them.
