Old 05-25-2011, 07:30 PM   #1
cutterbug's Avatar
2004 19' Bambi
afton , Virginia
Screen inside fridge vent
I have stinkbugs that love the louvered vents that open up to the back of the fridge. Will a metal screen on the inside of the vent prevent proper airflow required? There are 2 vents...one with the fan. I also have them coming in the AC slats. Has anyone ever screened the AC? Would that prevent proper airflow as well?
This is a desperate move....But I've had it with these things.
cutterbug is offline   Reply With Quote
Old 05-25-2011, 08:18 PM   #2
jackson center , Ohio
Any additional screening or filters will reduce air flow.The fan on the back of the refrig. is there to help air move across coils;so air movement is essential. Have you tried any types of repellants?
Schu is offline   Reply With Quote
Old 05-25-2011, 08:43 PM   #3
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Dave, stinkbugs are really bad, they seem to use normal insect repellent to gargle with. The only two things I've found to kill them is spraying them with strong soapy water, or flattening them with a shoe--or brick. And the soapy water doesn't work that well.
Old 07-19-2011, 08:08 PM   #4
1963 19' Globetrotter
Old Bridge , New Jersey
Try oil of oregano, or mint, from a mint plant or a concentrate.
Good luck.
njloco is offline   Reply With Quote
Roof Vent Insect Screen Installation Guym General Repair Forum 2 05-06-2011 07:08 AM
Screen on Sewer Vent 73 Tradewind constructor Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 03-20-2011 07:35 PM
Fitting a Nicro vent to the existing Hehr vent Globie64 Roof Vents, Skylights & Fans 8 03-17-2011 02:35 PM
Can you vent a battery through the fridge vent? Mike&Ali Batteries, Univolts, Converters & Inverters 22 03-07-2011 09:06 PM
