Old 08-25-2008, 01:59 PM   #1
1959 22' Flying Cloud
Seattle , Washington
Riveting a '59 FC Entrance Door.
I need to re-rivet the entry door to my '59 Flying Cloud. Q#1: what kind of rivets can I use? Q#2: Do I need to open interior to fasten the rivet? I'm desperate!
modernrat is offline   Reply With Quote
Old 08-25-2008, 02:20 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Modernrat,
It depends on what you need to rivet. Can you post a picture.
Bill
Just my personal opinion
Old 08-25-2008, 02:50 PM   #3
Door hinge repair - will post pics
The door hinge needs riveting to trailer wall. Shall post a pic this eve. Thanks.
Old 08-25-2008, 02:58 PM   #4
Over59's Avatar
Putnam , Connecticut
Images: 37
If they are off you will need to get the alignment right. These doors are a challenge. The original rivets are not aluminum on the hinges. I think they are a high strength stainless. I tried to drill one out of my 59 overlander and gave up. Need harder bit.
You will likly end up using a stainless pop rivet. Use the whole in the hinge to determine the size. Options 2 hope that Andy (Inland RV) has a response.
Over59 is offline   Reply With Quote
Old 08-25-2008, 03:00 PM   #5
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Modernrat,
I had the bottom hinge on the front door of my Liner come off the body this summer. The hinges were pop-riveted to the body. When I receive the new hinges, I will buck rivet them to the body, after placing reinforcements behind the skin.
What happened to the hinge?
Bill
Old 08-25-2008, 07:32 PM   #6
Here's a couple pics of my door-hinge problem:
http://picasaweb.google.com/kalunkal...17035154704530
Thanks Bill & Over59 for your input.
Dave
Old 08-25-2008, 08:21 PM   #7
Over59's Avatar
Images: 37
OK, those are not the same as my 59. Don't know what's original. Looks to me like you need some olympic pop rivets. You will need a rivet tool from sears. If you only need a few send me your address by PM and I'll send you some. If you need some for other areas they are easily had online.
Old 08-25-2008, 09:06 PM   #8
Area 63 Productions
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
Send a message via Skype™ to Area63
Here's what I would do.....your mileage may vary, and there's no batteries included...
Loosen and peel back the inner skins immediately behind the problem area.
Now, make some shims of aluminum from .050, or at least .032 sheet aluminum. Make the shim as large as possible, even if you have to use extra rivets to fasten it outside of the hinge circumference.
Drill the existing pattern into the shim, ( or backing plate, if that makes more sense)
Now fasten hinge with buck rivets to the outer skin, and backing plate.
The buck rivets will hold very well, and the backing plate ( shim) will give the assembly more stability.
You might have to do the same to the door as well.
Uwe
www.area63productions.com
Area63 is offline   Reply With Quote
Old 08-25-2008, 09:22 PM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
The rivets are MS20470AD5-X, X= the length in 1/16th inch increments. The rivet before bucking should protrude from the back side approx. 3/16". The doubler suggested by Uwe is an excellent idea. Put another row of rivets around the hinge but through the external skin and the new internal doubler. Do this on each side of the hinge, both top and bottom
Old 08-26-2008, 09:43 AM   #10
Thankyou Area63, Over59, wkerfoot & Aerowood! Think I'll go for the reinforced buck rivet plan. Pray for me.
mrat.
1959 flying cloud, door repair
Entrance Door won't shut! Kelly Green Doors & Locks 44 12-28-2017 01:21 PM
Entrance Door cooperhawk Airstream Motorhome Forums 4 08-26-2007 04:59 PM
small door on entrance door lwebb Doors & Locks 4 05-30-2006 09:11 AM
Entrance Door Fix Chaplain Kent Doors & Locks 0 06-30-2005 07:23 AM
Entrance door hardware 72 Overlander 1 Doors & Locks 7 01-14-2004 07:17 PM
