Old 06-24-2018, 08:09 AM   #1
1972 27' Overlander
Saline , Michigan
rivet for access door hinge
I have a 1972 27' international that is mostly original.
In the attached picture you will see rivets on my access door rusting.
Did Airstream use non aluminum rivets for these access doors?
I have the same rusting rivets on all my access doors.
These rivets appear to be a small buck or Olympic rivet but it is hard to tell with all the rust.
I was going to drill out and install 1/8 inch pop rivet, but I don't want to take on any leaks.
has anyone else seen or dealt with this?
loechli is offline   Reply With Quote
Old 06-24-2018, 08:45 AM   #2
2007 22' International CCD
Might be a pop rivet with a steel mandrel (the nail-like thing that sets the rivet when pulled by the rivet tool). It’s sometimes hard to find all-aluminum rivets in the big box stores. Time to drill them out, replace with all-aluminum ones...
Old 06-24-2018, 10:12 AM   #3
. , At Large
I've seen that quite a bit on those doors.
I think the thought at the time was to use steel rivets to better withstand the stress of the hinge.
Old 06-24-2018, 03:53 PM   #4
1972 27' Overlander
Saline , Michigan
we were wondering if it was a strength issue,
I wonder how many years that was done,
so should I replace the rusted with a pop or an Olympic rivet, do I need to be concerned about leaks in this area?
Old 06-24-2018, 07:28 PM   #5
Is there room and access to install stainless steel screws and self-locking nuts instead of the steel rivets? A dab of sealant under the screw head and a thin coat over it once tightened is another possibility...
Old 06-24-2018, 09:41 PM   #6
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
I would consider using tubular rivets like the ones on the windows if you want it to look perfect. VTS can get them for you, but I don't recall if it's on the website. I'd probably just use pop rivets, installed wet, and sealed. There's nothing inside the door that could potentially be damaged by a leak, and if it did leak enough to cause a problem, it would be easy to spot.
TheGreatleys is offline   Reply With Quote
Why did Airstream change from front hinge doors to suicide hinge doors? arcamedies Airstream History 28 08-15-2019 12:06 AM
'69 hinge window and access doors Harperbear Windows & Screens 2 12-02-2015 01:14 PM
Access door "hinge" redthies Exterior Storage Compartments & Access Doors 11 06-28-2015 09:47 PM
Door Hinge Rivet ttbikes Ribs, Skins & Rivets 1 05-31-2014 07:47 AM
Door hinge bolts/access hole ViewRVs Airstream Motorhome Forums 9 04-29-2003 08:44 AM
