Old 12-05-2006, 06:34 PM   #1
Guest
Question Refrigerator inspection compartment door hinge...
I have a 1973 Safari Land Yacht 23' that I am trying to get into shape. The Refrigerator inspection compartment door hinge is missing. I have no clue as to what it is even suppose to look like. I have no RV supply centers even remotely close to me. I think the easier would to be lucky enough to find a member to tell me possibly where to go online and order one if they still exist. Nevertheless, this old retired Military man is doing the best he can as we live in the South Georgia countryside and not close to much of anything, got to drive 13 miles just to get a quart of milk. Any and all help will be greatly appreciated as I have searched the internet pretty good but you guys seem to have a handle on most all questions.
gean235 is offline   Reply With Quote
Old 12-05-2006, 07:05 PM   #2
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Most of the Hatch Door hinges I've seen are like a Piano Hinge. You should be able to pick one up at a local hardware store. I would suggest the stainless steel hinge. Cut it to length and pop-rivet it into place.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 12-05-2006, 07:33 PM   #3
Some doors are still available for your 73.
Please post the dimensions of the opening, and we will try to help you.
Old 12-05-2006, 11:51 PM   #4
Guest
Thanks Andy, It is 20 1/2" wide and 15" high. I'd like to get by with just buying the missing hinge though. I think the piano hinge is not going to be "stock off the shelf" though.
Old 12-06-2006, 09:51 AM   #5
Now I know yesterday was a Monday.
I mis-understood.
The repair for your hinge is easy.
Go to home depot. Purchase a hinge that is about 12 inches long.
Mount the hinge at the BOTTOM of the door jamb.
Invert the door so that the lock is at the top, and set it into the jamb.
Fasten the hinge at what is now the bottom of the door.
The end result will give you an opening door with the hinge at the bottom. You will no longer have to take the door off so that you can access the back of the reefer.
Airstream changed to this setup in later years.
You have also eliminated the "J" hinge which has always been a pain.
Old 12-06-2006, 01:12 PM   #6
Guest
Thanks Andy, I will do that. What width piano hinge should I get as I remember they stock several? Thanks again. Morris
Old 12-06-2006, 01:19 PM   #7
The wider the better.
Use the full length of the straight edge on the door.
Old 12-06-2006, 05:48 PM   #8
Guest
I have some 1" wide piano hinge but I think I should get some that is wider according from what you might think is best.. Is that correct? Also, The seal is loose around that inspection door in question and what do you recommend to re-secure it in place? I also think I am going to have to purchase new top seals for at least one (1) top roof vent if not all. Is that seal sold by the foot? Thanks again..
Old 12-06-2006, 05:53 PM   #9
Each halh of the piano hinge should be 3/4 to 1 inch.
Unless it's already been done, all the exterior gaskets on your Airstream are past due for replacement.
Check the window, entrance door, access compartment doors, ceiling vents and the sewer vent pipe cover gaskets.
Many owners make a project by replacing all of them.
Storage Compartment Locks - 1968 Jim Clark 1965 - 1969 Globetrotter 14 11-08-2017 08:05 AM
compartment doors Dave Cole Exterior Storage Compartments & Access Doors 3 11-01-2016 11:17 AM
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
water seeping in compartment door Mike Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 10-23-2002 12:14 PM
Small LED above water heater compartment smily General Repair Forum 16 09-24-2002 01:30 PM
