Old 07-23-2011, 07:01 PM   #1
Hueytownalss's Avatar
Hueytown , Alabama
Rebuilding exterior access doors...
I am starting a thread for rebuilding the access doors on my 1978 Silver Streak. I am sure some of my AS friends have the same problem. Water, over the years, had gotten between the inner and outer layer, and had rotted the inside. The water made them heavy. The doors, I thought, had wood inside them. Instead they actually had some kind of pressed paper, maybe masonite. Either way it had to be rebuilt.
Initially I thought I would take them apart, put in new wood and put them back on. Then I thought I would try something a little different. This is my attempt to use spray "STUFF" foam inside the inner and out panels. This would make them lighter and water would not damage them in the future.
The first picture is the door as it was on the trailer.
Thanks, Jerry and Ginger
AIR 55079
"Son, you can do anything you want, as long as you can read".. J.P. Rambin
Hueytownalss is offline   Reply With Quote
Old 07-23-2011, 07:06 PM   #2
Hueytown , Alabama
The doors are riveted to the hinge, which is riveted to the trailer. There is a band around the door itself that have a couple of rivets holding it in place around the door skins.
I removed the rivets connecting the door to the hinge but left the hinge on the trailer. Then I removed the rivets holding the band to the skins, and finally removed the band. This is the band removed:
AIR 55079
Old 07-23-2011, 07:13 PM   #3
Hueytown , Alabama
When I got the band off and took the inner and outer skins apart, this is what I found!! A rotted mess!! Most of it just fell out.
This is what got me to thinking about using spray "STUFF" foam inside instead of wood.
ID:	135669   Click image for larger version
AIR 55079
Old 07-23-2011, 07:20 PM   #4
1977 31' Excella 500
plano , Texas
I would not use the spray foam. It does not handle water very well. Also it expands far more than you ever think it might. If you do continue with the spray foam, get the window/door version. It doesn't expand as much. I would recommend "foil bubble wrap". I don't know the official name for it, but it is used as radiant barrier in houses and can be bought at any of the big box home repair stores. If that is too thick, I would get roof sheathing. It looks identical to what you removed.
tschat is offline   Reply With Quote
Old 07-23-2011, 07:26 PM   #5
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Reflectix is I think what you're looking for the name of, tschat. Or perhaps you could buy rigid foam insulation and sandwich it between 2 layers of thin aluminum in the door. If you foam it, I agree get the window/door stuff. What you have in the can there, is supposed to expand lots, and will. Yeah, the old stuff kinda looks like Masonite. Doesn't tolerate water well. You probably need to put new seals on those doors so water doesn't get in (probably already thought of that, didn't you!).
Good luck!
Kay
Old 07-23-2011, 07:29 PM   #6
Hueytown , Alabama
Now, how do I get spay gooey foamy sticky gunk in side the two panels? Hmmmm!
I needed a form of some sort to hold the pieces in correct alignment and thickness. Remember the skins with the liner have to go back inside the band. The inside of the band was 7/16", and the thickness of the previous "wood" material was 3/16".
First, I cut two pieces of 3/4 plywood, (I just happen to have it already), to the exact side of the panels. Then I glued and nailed plywood cleats, or stops, to one of the panels.
AIR 55079
Old 07-23-2011, 07:40 PM   #7
Hueytown , Alabama
Tschat and Minno, Oops!!! Already used the foam!!
Water actually got in because of the lock, and the small crack where the band meets. I intend to seal everything with Trempro 635 when i put the band back on.
I thought I would use the swelling of the foam to my advantage. When I got my "contraption" together, the swelling would push the panels apart to the correct thickness. But I'm jumping ahead on my story.......
AIR 55079
Old 07-23-2011, 07:51 PM   #8
Hueytown , Alabama
Next I cut spacers exactly 3/8" thick. These would be used between the panels to keep them apert the correct thickness. The ouside thickness of the two skins and the spacers came out to exactly 7/16", and will fit back in the band.
The following pictures show the first skins, good side down. Then with the spacers. Then the other panel, good side up. Then the other pece of plywood.
I pressed these pieces tight a screwed the the cleat into the top piece of plywood.
There is info about the lock area, but I will get to that shortly.
ID:	135683   Click image for larger version
ID:	135685   Click image for larger version
AIR 55079
Old 07-23-2011, 07:53 PM   #9
Hueytown , Alabama
you can see the thickness in this picture.
AIR 55079
Old 07-23-2011, 08:01 PM   #10
Hueytown , Alabama
Around the lock area, I thought I would "beef" up. The lock has a little screw that attached from the back side of the door. It also went into the wood, before.
I looked for something aluminum as a replacement, and also cheap. I found in my storage, an old threshhold that I could use to "beef" this area up. I will post profile picture of this piece when my phone charges.
The following pictures show the piece cut and in place before the foam goes in.
ID:	135688   Click image for larger version
AIR 55079
Old 07-23-2011, 08:55 PM   #11
Hueytown , Alabama
I tried it and it worked!!!! BUT DO WEAR GLOVES WHEN USING THE FOAM SPRAY!!!! It is STICKY!!!!
I spayed the foam in from the top. I forgot to take pictures after I spayed foam in the form, because I got some of the STUFF on my hands, and it IS sticky.
After the foam expanded, I took a nap while it cured. A couple hours later I took the door out of the form, and removed the spacers that were on the edges. I then sprayed the gaps where the wood edge spacers were and let that set. the pictures shown are after is is out of the form. Then trimmed up a little.
ID:	135691   Click image for larger version
ID:	135693   Click image for larger version
AIR 55079
Old 07-23-2011, 08:57 PM   #12
Hueytown , Alabama
The last picture, in last post, shows my supervisor, Max! I run all my projects by him first.
Will put the band back on tomorrow, and polish the door. Polishing the door is in conjuction of another project on my Silver Streak. It is anodized aluminum. I am de-anodizing it so that it will polish. I have that in another thread. It is so HOT here in Alabama, that I can work on the polishing only a few hours a week.
Not sure how to link a thread, but you can find it by searching for Polishing Silver Streak Project.
AIR 55079
Old 07-23-2011, 09:07 PM   #13
Hueytown , Alabama
This might work:
http://www.airforums.com/forums/f441...ect-78246.html
AIR 55079
Old 07-23-2011, 10:24 PM   #14
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
I think that I recognize the look on Max's face . . . . loosely interpreted . . . . You've spent enough time on that project, now it's my turn. Pick me up and give me some attention too,
My toy Chihuahua is often in a similar position only she will start to cry if I ignore her for too long.
Kevin
My two supervisors (Precious Princess and Prince Little Bear):
Kevin D. Allen
AIR #827
storage doors, door
Using VTS Service Vent Doors? worldinchaos Exterior Storage Compartments & Access Doors 7 08-19-2011 01:26 PM
Help: 1976 28' bottom doors MrJ Argosy Motorhomes 1 07-23-2011 08:31 PM
Excessive stress on cabinent doors? Airslide General Interior Topics 8 06-26-2011 09:46 PM
Rebuilding Cabinet Doors webspinner Cabinets, Counter Tops & Furnishings 14 03-28-2011 10:29 PM
Want to replace kitchen tambour doors Gkiesel Cabinets, Counter Tops & Furnishings 0 03-13-2011 06:33 PM
