Old 11-16-2008, 10:39 AM   #1
1977 31' Excella 500
portland , Tennessee
Question about insulation
Can someone tell me if the foil/foam/foil insulation in a 1977 excella is asbestos? Also what similar insulation is available to purchase. We need more at every opening. We are going to live in it and it is missing most of it. All the access doors are drafty.
netlace is offline   Reply With Quote
Old 11-16-2008, 10:49 AM   #2
lynn's Avatar
It should have had fiberglass insulation in the walls.
lynn is offline   Reply With Quote
Old 11-16-2008, 10:57 AM   #3
This is not in the walls. It is pieces cut to go in the openings. It is foil/foam/rubber/foil about 1.5 inch thick. the foam is black, heavy.
Old 11-16-2008, 11:06 AM   #4
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
What openings? Photos would really help.
Vaughan
Old 11-16-2008, 11:47 AM   #5
The access doors. behind fridge, under beds....When I go to the property I will get pictures.
Old 11-16-2008, 02:05 PM   #6
1983 34' Excella
1967 24' Tradewind
Images: 32
Rivet No Idea
My under the bed doors have nothing like that. Rubber gaskets, but nothing like you are describing. The one behind the refrigerator doesn’t even have a gasket. It does have louvers to let air in for combustion. The fridge in my Excella is over the wheel well.
If you look at the photos of the inside of the refrigerator cabinet at http://www.airforums.com/forums/f425...aes-44474.html you can see the inside of the door. It is covered with plastic to keep the mosquitoes out, but you can see that there is nothing like what you are describing.
I will watch for the photos. It could be something a previous owner made. You have my curiosity peaked now.
Vaughan
Old 11-16-2008, 04:35 PM   #7
lynn's Avatar
It sounds like someone has added some sound deadning insulation to your trailer.It was not original unless it was a commercial unit.
Old 11-25-2008, 11:49 AM   #8
clio , Michigan
Yeah, fiberglass. I agree with poster two.
dantheman972 is offline   Reply With Quote
Wheel well crack and insulation question vhord Wheel Wells 14 05-21-2009 04:16 AM
Spray Foam Insulation Question Gkiesel General Repair Forum 3 04-08-2008 01:08 PM
Insulation BB 55 Bubble General Interior Topics 1 06-09-2007 11:21 AM
Insulation C Johnson General Interior Topics 22 04-30-2005 02:12 PM
Re-insulation pbt45 Commercial Listings 1 02-27-2004 10:25 AM
