Old 04-01-2008, 08:57 PM   #1
ayresdream's Avatar
1971 29' Ambassador
Merritt , British Columbia
Putting Hinge on Compartment Door
I want to put hinges on my compartment doors. A trip to the local building supply store had piano hinges with a nickel coating. Can I use that on aluminum, or should I get aluminum piano hinges? Any suggestions of suppliers?
ayresdream is offline   Reply With Quote
Old 04-02-2008, 07:47 AM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Do not use steel piano hinge. Use aluminum piano hinge. The best is the extruded MS20001 but a rolled hinge will work. Both are available here
McMaster-Carr listed under "aluminum continuous hinge" pages 2933 & 2934
Compartment door hinge/safety latch/wire rideair Exterior Storage Compartments & Access Doors 6 05-11-2010 01:24 PM
battery compartment hinge replacement flash Classic Motorhomes 2 04-25-2007 06:03 PM
Refrigerator inspection compartment door hinge... gean235 Exterior Storage Compartments & Access Doors 8 12-06-2006 05:53 PM
Door Hinge CharlieBrown 1998-1999 Limited 7 07-16-2006 08:07 PM
Door hinge bjstewart1 Doors & Locks 0 10-09-2002 06:22 PM
