Old 02-07-2012, 11:33 AM   #1
2004 16' International CCD
Orem , Utah
Problem w Gaskets on rear door storage access
Ok just spent some time looking at mine there are 2 locks that help pull door close. Well there is so much room between gasket and door that i see daylight coming through. if this is stock weather seal gasket I am shaking my head! I am going to contact Airstream but first thought i would share my findings. Can anyone get me a picture of there rear hatch door in closed position from inside trailer. Also wanted to see how your latch plates are installed. I am thinking another 2inches of rubber thickness would not hurt. That is way off and can not think product like this would be put together so poorly.
starcraft is offline   Reply With Quote
Old 02-07-2012, 12:24 PM   #2
"CLOUDSPLITTER" (tahawus)
ROBERT CROSS's Avatar
Hoover Beach , "Niagara Frontier" NY
Images: 53
star,
Our "trunk" is full so an interior pic would be hard, just wondering if yours is the same as ours?
Had a leak there last Spring but it wasn't the door gasket.
I did adjust the latch arms to get the outer edge even on both sides.
I'll try for a pic of the gasket and latches.
Got a pic of yours?
LOST IN THE SIXTIES
" I'll know where I am when I get there"
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 02-21-2012, 08:24 PM   #3
Orem , Utah
I did get this adjusted better
I pulled gasket cleaned put some 303 on it and bent metal inside little bit to help pull it out more. Then I adjusted the latches tighter by spinning nut and bent latches by hand. All this alum is easily messed up by wind or grumpy owner. Another thing I adjusted front and rear windows and adjusted nuts so glass fitted tighter. Fixed few issues these AS need little loving every now and then.
Old 02-21-2012, 09:11 PM   #4
Images: 53
Star,
Best pic I had of the "trunk"... I did pretty much the same thing to get the door to fit evenly side to side.
My leaks were at the bumper belt moldings, tail light housings license plate bucket. Repaired last Spring SFSG.
Good luck wit yerz...
LOST IN THE SIXTIES
Bob,Sandra & "Fado"
2006 3/4 Burb 8.1
Hensley
Old 02-21-2012, 11:12 PM   #5
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
Storage door seal.
Hi, My storage door allowed cold air into it, and under my bed. I attempted to pad the factory weather seal, but with the hatch locked, I could easily push the door in about a half inch. My cure was to buy some "D" shaped weather seal from Lowes and wrap it around both edges of the door. This makes for a snug, leak free storage door. If your door is square, it might not work as well as my rounded door.
ID:	151669   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 02-23-2012, 04:16 PM   #6
Orem , Utah
how did you get license plate light and hardware off
I tried and quit because it felt like it was stuck. Remove chrome piece then 2 screws in front right. Also how did you caulk the tail lights? I did acrylic r where alum meets housing. The bottom led has water inside now just how did it get there. Was thinking about using black silicone inside the trim. I did clean black rubber inside had quite few alum shavings and dirt on lower portion. Also your picture looks like what I was going to do. Put D seal under old rubber to add some thing for door to push against.
Exterior AC Plug Door MaxAB Exterior Storage Compartments & Access Doors 4 02-24-2012 12:23 AM
Problem w Gaskets on rear door storage access starcraft Exterior Storage Compartments & Access Doors 5 02-23-2012 04:16 PM
When gas goes up More RVs On Craiglist Lothlorian Off Topic Forum 0 02-23-2012 10:22 AM
Changing faucets 71 rear bath 31 Excella slolearn Plumbing - Systems & Fixtures 0 02-23-2012 09:03 AM
