Old 05-02-2015, 07:33 AM   #1
rochar3's Avatar
2003 31' Classic
Valparaiso , Indiana
Question outside compartment floor rusted out
'03 31' classic has outside compartment floors rotted out. One small one on right side and left water compartment. What is the usual fix. Repair parts or local sheet metal??
As usual, thanks for help.
Bob-air # 657
I can win any argument on any subject. People know this and steer away from me at parties. Often as a sign of their respect, they don't even invite me.
rochar3 is offline   Reply With Quote
Old 05-02-2015, 07:56 AM   #2
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Not all AS created equal, my compartments are constructed of aluminum, body is fiberglass but the framing between is steel that I have found rust on, I can only get at a small section of it. I painted rust remover to try and change rust to non rusting oxide. When we had autos that had small holes in floorboards we could overlay larger sheet but never a permanent fix as long as metal kept rusting.
Old 05-02-2015, 08:19 AM   #3
2010 27' FB Classic
N/A , Texas
Bob,
If the ones your talking about are cut into the bottom wrap ( originally white painted steel), Airstream sells replacements as an upgrade and they are made from aluminum instead of the OEM steel ones. Or, you can buy the steel OEM replacements as well at less money.
Old 05-02-2015, 08:40 AM   #4
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
I removed sandblasted then repainted and reinstalled.
AS has fresh sheet metal replacements. A local sheet metal shop can build for you of course.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-02-2015, 03:57 PM   #5
jackson center , Ohio
They have replacements for sale thru Airstream that are stainless steel instead of powder coated steel
Schu is offline   Reply With Quote
Old 05-02-2015, 04:09 PM   #6
tjdonahoe's Avatar
2013 31' Classic
billings , Montana
Take the old one off, sandblast it, weld in a patch panel, paint and you are good to go
Old 05-02-2015, 06:43 PM   #7
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
We replaced ours that were already rusting with the factory stainless steel replacements.
Old 05-02-2015, 09:52 PM   #8
2010 27' FB Classic
N/A , Texas
Thanks for correcting me about the type of metal the upgraded ones are made of that AS sells. I guess I was thinking stainless and typed aluminum. I think I have aluminum on the brain!
Old 05-03-2015, 06:39 AM   #9
rochar3's Avatar
2003 31' Classic
Is this a part I can order on line or do I have to go thru a dealer? Also, How difficult to install?
Bob-air # 657
Old 05-04-2015, 04:29 AM   #10
They can be ordered thru any Airstream Dealer or contact Airstream at 937 596 6111 ext. 7400
It is not to bad to install but there is a city water hook up that will need to be Removed and reinstalled along with compartment door.
Old 05-04-2015, 06:57 AM   #11
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Seems like Silver Trailer Supply has the aluminum replacements for less money than Airstream. Google it.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 05-04-2015, 09:43 AM   #12
rochar3's Avatar
2003 31' Classic
rivets for compartment door
What size rivet do I need to attach door to SS replacement compartment?
Bob-air # 657
Old 05-04-2015, 11:16 PM   #13
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ours were 1/8" diameter, 1/8-1/4" "grip range". I used a little deeper then added washers on the 'grip side'...
Use a drill bit to gauge the size of the holes..
Channing
WBCCI# 30676
Old 06-02-2018, 08:16 PM   #14
Pasadena , Maryland
Hi, has anyone been able to find these compartments recently? I don't know if I'm searching wrong or if they don't offer them anymore but I can't seem to find replacements... the floors of my outside storage compartments are rusted out. A link would be greatly appreciated
ceaton1 is offline   Reply With Quote
Rusted out tank on 29' '85 Sovereign my3sonsdad 1984 - 1989 Sovereign 3 07-23-2011 01:01 PM
steps rusted out? ClayC Steps 5 09-16-2009 08:43 AM
Step slide rusted out Odessa-Don Steps 3 05-31-2009 02:46 PM
Toilet bolt rusted out--ideas?? cosmo9404 Waste Systems, Tanks & Totes 7 04-21-2007 07:46 PM
Hitch/Frame Rusted Out airdreamer Repairing/Replacing Floor &/or Frame 13 05-06-2004 11:39 PM
