Old 03-27-2010, 09:33 AM   #1
1968 17' Caravel
Tacoma , Washington
OOOps. Dropped my cargo hatch :-(
I have a '68 Caravel. I was on a road trip and dropped the removable cargo hatch that covers my battery and storage. It was completely destroyed, exploding into hundreds of little aluminum scraps. How do I find another or get another made?
Futuramic76 is offline   Reply With Quote
Old 03-27-2010, 09:37 AM   #2
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Welcome to the forums!
Hi Futuramic76, I you need one right away then Inlandrv has them. If you can wait try ebay or take a look here under salvage yards. Parts and Suppliers Sites - Links Directory
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 03-28-2010, 11:41 AM   #3
Homewrecker's Avatar
1964 22' Safari
Indianapolis , Indiana
sorry to hear that!!
Don't get your hopes up, but DO try
Vintage Camper , Peru, Indiana
Homewrecker is offline   Reply With Quote
Old 03-28-2010, 01:34 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
maybe here
1963 - 1969 Airstream trailer Refrigerator, Rear, & utility access doors - Airstream Trailer Classifieds - Used Airstreams For Sale
Old 03-28-2010, 01:40 PM   #5
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
Send a message via Yahoo to Boondocker
You probably lost that door due to rear end separation, I would get that fixed before putting a new one in. I also believe that vintage trailer supply has started to manufacture them as well.
Rodney
Visit my photography page
and the
Favorite camp grounds project map
My Blog
(The artist formerly known as General Disarray)
Boondocker is offline   Reply With Quote
Old 03-28-2010, 05:33 PM   #6
1967 22' Safari
1960 Caravel
Images: 8
Only one service door that I can see. In front of the axle...Probably not rear end separation.
1968Caravel2
Lee
1973 F-250 4X4 390
AIR 6030
WBCCI 4258
TCT
Old 03-28-2010, 05:43 PM   #7
Naysayer
Boondocker's Avatar
1968 24' Tradewind
Louisville , earth
1968Caravel2
DOH! I assumed (dont say it) it was a rear panel. Still, that door shouldnt be able to come out without the latch failing or frame separation.
Rodney
and the
My Blog
Old 03-28-2010, 06:34 PM   #8
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
I worry about mine, I always make sure it is securely latched and locked before we move. I imagine a replacement would be pretty hard to find.
Stephanie
Old 03-28-2010, 08:35 PM   #9
65Safari65's Avatar
1965 22' Safari
Staunton , Virginia
I kinda live in fear of this, too. I've considered a wire attachment line that would be short enough so that it wouldn't drag on the road if it came off. Maybe a small hook on the back of the panel so that when the door is off, it could hang from a little loop attached to the skin? A little invasive, but better than the terror of the access door search.
That being said, there seem to be more options for replacement out there all the time- good luck, I bet you can find one. If you don't find an actual replacement, I think a thicker piece of aluminum with some reflectix insulation on the back and a lock mounted through it would be a good interim fix.
65Safari65 is offline   Reply With Quote
Old 03-28-2010, 09:18 PM   #10
access doors.
Access doors on the 64 to 68 trailers, do have a tendancy to fall off.
The worst case, is the rear door. Usually, rear end separation, separates the rear access framing at the lower corners, which then enlarges the actually opening, resulting in the door falling out.
The side access doors, when they fall off, is usually because of a poor lock adjustment and/or a bad gasket.
A good gasket for those doors, also stops them from moving and looking for the right bump, then falling out.
The fix is easy. Have tight gaskets and have the lock paddle or arm, adjusted so that you must push in the door a little, in order to properly lock it in place.
Our experience is that probably 95 percent of those access doors that fall off, could have been avoided.
The other 5 percent is due to rear end separation.
In the case of these doors, a little PM, goes a long way.
Look who dropped in for the holidays... overlander63 Off Topic Forum 16 04-20-2009 05:35 PM
Dropped off in the driveway... GEARHED Member Introductions 6 08-24-2007 03:18 PM
Ooops! Minnie's Mate Axles 43 06-23-2006 07:29 PM
Logged in....dropped off pyanke Forum Admin, News and Member Account Info 9 03-03-2004 08:54 AM
My Suzuki Samurai dropped into gear while being towed williamhenshall General Motorhome Topics 16 04-07-2003 09:30 AM
