The exterior compartment doors (fridge and battery access) on my Caravel simply detach when opened and are usually a PITA to get back in place. Would it be a major job to install piano hinges or such?
It may sound like a minor inconvenience but once the flanges get bent, getting the doors back on can cause a guy like me to nearly exhaust his cussword vocabulary.
Has anyone else found this to be a problem in need of a solution? Any and all suggestions welcome.
That sounds like great advice as usual. I'm unclear as to what a "J" hinge is but perhaps I'll understand better next time I examine the doors (the trailer is stored 10 miles from my home).
Sure is nice to have a resident AS expert on board. I'm betting that others will also benefit from this very helpful info.
It all makes sense now, or, in my case, to quote the lyrics from a famous song:
"I can see clearly now, the brain is gone".
[Lightning flashes, thunder crashes] "It's alive... the thread is ALIVE!!!"
I want to put hinges on my compartment doors. A trip to the local building supply store had piano hinges with a nickel coating. Can I use that on aluminum, or should I get aluminum piano hinges? Any suggestions of suppliers?
Me too, me too, I need piano hinges. Can sure relate to the frustration of trying to get that @#$% little door back in its little hole with the bent "J" hinge! I was thinking of hiding the kitty litter near a compartment door so it would slip out easily. I'm interested to hear any answers to ayresdream's questions.
Thanks, Gwen
You should use aluminum hinges, but plated is ok too.
