Old 07-10-2014, 09:10 AM   #1
Heliguy63's Avatar
1964 28' Ambassador
henderson , Nevada
No key for outside compartment.
I have no key for this outside compartment. Any ideas of how to open it without damaging it? It is easy to find a replacement lock?
ATTACH]216066[/ATTACH]
Name:	ImageUploadedByAirstream Forums1405004969.363810.jpg
Heliguy63 is offline   Reply With Quote
Old 07-10-2014, 09:11 AM   #2
Heliguy63's Avatar
1964 28' Ambassador
henderson , Nevada
Oh it's a 64 ambassador.
Old 07-10-2014, 09:39 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Here's a post with a link to a useful key-fitment chart for vintage Airstreams.
It says you're looking for key# 166, but I don't know where to find that one. I didn't find it at Out Of Doors Mart, for example, where I was able to purchase the hard-to-find key for '70s water-fill doors.
David
Old 07-10-2014, 10:38 AM   #4
Cyquest's Avatar
1969 23' Safari
Blenheim , Ontario
Try a lock smith. They would at least be able to open it. Good luck!
Cyquest is offline   Reply With Quote
Old 07-10-2014, 11:04 AM   #5
RickDavis's Avatar
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown , Tennessee
If you can access the door from inside the trailer remove the large screw that holds the locking tab to the lock. You can buy replacement locks for under $5.00 at almost any RV store or from Vintage Trailer Supply
It is not worth the cost of a lock smith
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
Old 07-10-2014, 11:08 AM   #6
1974 Argosy 20
Kooskia , Idaho
It is a simple baggage lock, available at most hardware stores and RV parts places. If you can get to see the inside by removing any interior items, you can take a screwdriver and remove the inner tang which is held on with just one screw. That way you can open the compartment and take the lock out. Then replace it with one from the hardware or RV store.
Old 07-10-2014, 02:56 PM   #7
Heliguy63's Avatar
1964 28' Ambassador
henderson , Nevada
Cool thanks I plan on replacing the entire sub floor. I will wait tell in have the floor out and I can access the back of the compartment. Wonder what goods I might find.
Old 07-10-2014, 05:42 PM   #8
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Most of us with older coaches have keys we'd had no clue about, but I've opened many other panels with those keys.If you could find a AS, they mite have the key.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 07-12-2014, 09:02 AM   #9
jcain63's Avatar
1972 25' Tradewind
lancaster , California
I had the same problem with my 72 TW. I ended up ordering new locks from vintage trailer supply and drilling out the old ones. On a good note, vintage trailer supply keyed them all same.
jcain63 is offline   Reply With Quote
Old 08-03-2014, 09:25 PM   #10
1977 23' Safari
1986 34' Limited
Idaho Falls , Idaho
I understand that Airstreams of the same year and/or size often have keys that fit each other, so if you can contact a Forum member with the same unit you have, maybe they would be willing to send you a duplicate of their key.
Good luck!
Vivian
Richard and Vivian
Caliban The Wonder Dog: gone but not forgotten
Cerberus
Too many vintage A/Ss...
Landshark is offline   Reply With Quote
Outside Fridge Compartment Door Lock Cathy Libby Exterior Storage Compartments & Access Doors 6 11-08-2017 04:57 AM
Key for outside utility shower door? irm Doors & Locks 0 03-30-2014 02:20 PM
Keys for outside compartment doors Arizona Al Exterior Storage Compartments & Access Doors 30 08-13-2011 08:32 PM
Entry door bolt lock with an outside key willyd Doors & Locks 4 06-22-2008 01:07 PM
key for my water compartment door! pamelake 1970-79 Tradewind 14 07-27-2005 11:47 AM
