Old 08-14-2010, 07:09 PM   #1
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
New Compartment doors - How do I cut the holes for the locks?
Brand new doors rec'd today. Need to cut the holes for the new locks. I know that there are specialty hole saw bits for metal... Is that what I need? Hate to have to drop 100 bucks on a set of bits for 2 access doors. I doubt I would ever use them again. I'm sure I can't use wood hole saw bits. Any ideas?
NicheVintage is offline   Reply With Quote
Old 08-14-2010, 07:20 PM   #2
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
A step bit, may do what you need and it it a lot cheaper than a hole saw. Check Harbor Frieght.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-14-2010, 07:24 PM   #3
68 TWind's Avatar
1968 24' Tradewind
Here is a link, sorry I didn't put it in first post.
Search results for: 'step bits'
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 08-14-2010, 07:26 PM   #4
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
I’m guessing you are putting in the key locks with the flat sides on the barrel to keep them from rotating.
I’d get out my Uni-bit step drill, and fine tooth round and flat files.
Drill out the center of the hole to the width of the flats, and then finish the opening with the files.
All of these tools are at your local hardware or big-box store. Probably won’t spend more than 30 bucks.
The Uni-bit is one of the handiest tools for making holes in sheet metal. You definitely be using it again.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Storage Compartment Locks - 1968 Jim Clark 1965 - 1969 Globetrotter 14 11-08-2017 08:05 AM
Unlockable compartment locks bkahler Argosy Motorhomes 25 10-27-2009 07:58 AM
replacing compartment locks Dave Cole Exterior Storage Compartments & Access Doors 3 08-14-2008 07:34 PM
1970 compartment locks vhord Exterior Storage Compartments & Access Doors 3 03-18-2008 01:29 PM
Exterior Compartment Locks. Navigator Exterior Storage Compartments & Access Doors 12 03-10-2006 11:05 PM
