Old 01-24-2009, 07:39 AM   #1
SaabLover's Avatar
Almost Always Sunny Sarasota , Florida
Images: 12
My Entry Door Hinges Are coming Loose
This has been slowly getting worst and worst. Now the latch on the door is not catching at all. Since I am full timing in my AS this is most annoying in the colder weather and the door is open just enough to let in unwelcome cold. Well at least I am living in FL and it's not too bad.
The slotted bolts on the hinges just spin and I cannot get them out. only one seems to be holding at all. So even If I wanted to take my 35 year old Sovereign out on a road trip I couldn't because the door is open just enough to catch the wind. Any help on this would be appreciated. I did a search but didn't come up with anything that referred to it.
Thanks, SL
1999 Chevy Suburban 7.4LT "Tugger" Last of the big boys! Still going strong. 1992 Saab 900s Convertible 60K miles Not my TV
Almost always sunny here unless there is a hurricane bearing down on you. And then it's time to hook up the burb and roll. So far I've been very lucky.
SaabLover is offline   Reply With Quote
Old 01-24-2009, 08:34 AM   #2
Central , Mississippi
If your '74 is like my '77 the problem is the nuts have fallen off or loosened on the back of the hinge.
My PO lost the keys and tryed removing the hinges by unscrewing the flat heads. The nuts on the back side have some sealant that sort of holds the nut and allows the nut to break loose but it may not come completely loose. Either way, the sealant doesnt seem to offer any help when ya try to retighten the bolt.
I used a 1" hole saw in a drill and made a hole in the interior skin exactly between the two bolts of each hinge. This allowed me to wiggle a new nut on the back of each screw and hold it while the screw is tightened.
The only other solution I could see involved removing the kitchen cabinet, drilling out the interior skin...
I guess I should look for some 1" chrome snap in inserts to fill those holes someday...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-24-2009, 08:44 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
You can find them in the electrical department at Lowe's and Home Depot. They are used to fill holes when wires are removed from fuse panels. They come in different sizes to match the holes.
Richard
Old 01-24-2009, 08:50 AM   #4
Thanks, SL
Main door hinges coming loose, is not unusual. The cause is well known.
Find the cause, and correct it.
The causes, based on my over 40 years with the Airstream product are all simple and easy to correct.
The number one cause is lack of proper running gear balance.
The other causes are using a tow vehicle that has a suspension to tow the Queen Mary, namely way way too heavy a duty, and a hitch rating that is excessive as well.
Next is bad axles. We all know that from 74 on back, all the axles are doomed. But later year axles also fail, for a variety of reasons, such as being parked for a long time, 2 years or so, and overloading. The rubber rods must be exercised. If not, they will give out and/or solidify. In either case, the shell and it's components will suffer damages.
That happens to any torsion axle, regardless of manufacturer.
Airstreams love a soft ride. They are built that way. When that ride is stiffened, many many damages occur, including the door hinges.
Old 01-24-2009, 11:15 AM   #5
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Good post Andy! Very informative. I was amazed at the differences after my new axle was put on.
Thanks for all of your insight!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 01-24-2009, 03:36 PM   #6
SaabLover's Avatar
Images: 12
So I was afraid of that. At first I thought that they might have just stripped out, and I could install a heili-coil. I can see no other way to access the nuts other then drilling an access hole. I really don't want to remove the cabinets at this time. I think I will try to find the hole plugs first as to not having to be limited to a set size. If 1" is it then so be it. I'll check at Lowes first then the local Ele. Supply house. I know that I have seen what you are talking about around but never had need of any.
Thanks, SL
Old 01-24-2009, 04:09 PM   #7
mapley3's Avatar
1980 31' Excella II
Spring Hill , Florida
Our 1980 entry door needed hinge bolts and alignment. Not having a specialized wrench to reach two bolts through one small hole, we cut a rectangular hole exposing both bolts on both hinges. We were able to cut excess inner skin material from inside a wardrobe and rivet same over the holes when finished. An AS factory mechanic told us to always use TWO nuts per bolt to keep them tight longer. Good luck and happy travels.
mapley3 is offline   Reply With Quote
Old 01-24-2009, 05:09 PM   #8
It's also wise to coat them with Vulkem sealer.
Old 01-30-2009, 11:31 AM   #9
... Not having a specialized wrench to reach two bolts through one small hole, ...
My specialized wrench was, well - I glued the nut to the end of my finger in a position so I could poke my finger in the hole and the nut was close to the end of the bolt. I got the wife to turn the screw until the nut started on the screw and then came loose from my finger. I could then stick an open end wrench on the nut and complete the tightening.
Like Andy said, some sealant was used to keep things from leaking and/or backing off.
They are still tight 12,000+ miles later!
Old 01-30-2009, 12:10 PM   #10
Diesel1's Avatar
1967 24' Tradewind
Wickenburg , Arizona
Use red Loctite.
Diesel1 is offline   Reply With Quote
Old 01-31-2009, 04:40 PM   #11
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
I drilled a hole straight thu, used a SS flathead bolt then used an acorn lock nut looks like it belongs there.
'77 Sovereign Intl 31' CB
Old 03-21-2009, 11:20 AM   #12
Ottawa , ON
Andy, what is it that's special about the 1974 and previous axles? Why in particular would they faill more that the newer ones?
Old 03-21-2009, 11:38 AM   #13
2002 25' Safari
Dewey , Arizona
Images: 62
My understanding is that a different rubber was used starting with the 1975 units. These axles will fail also if left sitting too long, but overall should have a longer life.
Richard
Old 03-21-2009, 07:50 PM   #14
Ottawa , ON
Hmm, good to know. Those are the years I tend to see a lot of in my price range. Thanks, Richard.
Entry Door Hinges gunworks Land Yacht/Legacy Motorhomes 10 11-02-2018 04:32 PM
2004 Classic Trim coming loose IrishRover2 General Repair Forum 6 03-28-2008 06:06 PM
Door hinges loose Blimphauler Doors & Locks 7 11-20-2006 03:22 PM
Door hinges & new screen door? JKWoodrow Doors & Locks 5 11-17-2006 09:39 AM
hinges for a '63 entry door? 59er Doors & Locks 7 05-03-2005 07:37 AM
