Old 10-06-2013, 05:03 PM   #1
Baltimore , Maryland
L100 & L200 Issues...
I have been dealing with a reoccurring issue(5 times now) of clients unable to get into their trailers due to a serious flaw in the design of their door lock set. I am hoping to help some of you not run into the same issue. It happened to me today and I thought I would share what happens, why it happens, and how to avoid it happening to you...
Many of you have the lockset above in your unit. It was made by Bargman Co and was used 1961 thru 1968 in just about every model. Both the L100 and L200 look the same on the outside. The L100 uses the same knob on the interior as the exterior.
The L200 uses an interior handle like the one pictured above. These locks were discontinued about two years ago. While still manufactured they sold for $85. Now that they are no longer made, the price has been jacked up to over $250. I saw one sell on Ebay for $450 just last week. When it fails, it seems as if all is lost and it needs to be replaced. 90% of the time it is a simple fix, so simple it makes you feel foolish to think it was even a lost cause...
If you unscrew the back side of the lock set. See middle photo... those two screws... just remove them and the back comes right off.
In the very center of the exterior knob is a screw shown above. Tighten it and suddenly the lock works again. If that screw loosens just a little bit, it fails to work for you. I suggest that the screw be removed and re installed using a little LockTite to keep it from coming loose in the future.
I hope this helps even just one of you...
Old 10-06-2013, 05:13 PM   #2
Central , Mississippi
Thanks Frank!!!
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 10-13-2013, 10:31 AM   #3
Barkingdogg's Avatar
Newcastle , Oklahoma
I have been locked out because of this. If it happens before you fix, hold the exterior know square with the door and push hard while turning. Has gotten me in before I put a lock washer on the screw.
Barkingdogg is offline   Reply With Quote
