Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Exterior Storage Compartments & Access Doors
Old 07-21-2005, 01:06 PM   #1
Really Cheap
tmcdougald's Avatar
Is this door supposed to fall off?
CS Rear door just falls off when i open it.
Jevons paradox: Increases in efficiency lead to even larger increases in demand.(Basically means that there is no hope for the energy and resource problems on this planet.)
tmcdougald is offline   Reply With Quote
Old 07-21-2005, 01:19 PM   #2
I'm afraid not.
Tech98 is offline   Reply With Quote
Old 07-21-2005, 01:29 PM   #3
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Maybe
It is not the first one I have seen.
You need to look at how it attaches at the top.
If there is evidence of a Hinge or other attaching bracket then maybe it did have one at one time or other. Sometimes, covers are simply a catch like bracket that slides into place.
smily is offline   Reply With Quote
Old 07-21-2005, 01:44 PM   #4
early's Avatar
Ours come off to, you have to hold them when you open them. If you raise them too high they will come off. Both of our panel doors come off. I think on the older units they are supposed to do that. Dawn
early is offline   Reply With Quote
Old 07-21-2005, 01:45 PM   #5
Tarheel's Avatar
2001 34' Limited S/O
Moyock , North Carolina
Images: 21
Mine (74) just had a clip that it fit into at the top. You would hook it in then secure it with the lock. It was kinda nice that it would come completly off and allow better access.
Keep the shiny side up.
WBCCI # 348
Past Region 3 President
Past President Tidewater Unit 111
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 07-21-2005, 01:59 PM   #6
mandolindave's Avatar
Mine came off too. The lock and a channel held it in place. I guess that
it wasn't locked very well and I dropped it on the highway, and couldn't find it. It is hard to find a replacement. I was lucky and got a door with a riveted hinge as a replacement. I suggest attaching it with a safety chain so you won't lose it.
mandolindave is offline   Reply With Quote
Old 07-21-2005, 02:21 PM   #7
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Fall off, NO, remove after un-locking yes. My 75 has the same door. Here is a pic of it when I we removing the clear coat.
http://www.balrgn.com/Polish/DSC02681.jpg
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 07-21-2005, 02:32 PM   #8
2005 22' International CCD
Buckhorn , Ontario
I'm with the fall off no - remove after locking crowd.
Ours are the same way - if you hang onto them after you open they will stay in place - but turn them or lift them too high and they will come out of the track.
I would venture a guess that they were made that way - most of the compartments on the older coaches were for running gear tools, water and electic - so the last thing you want is a door that you have to hang onto and fandangle with while trying to get to the things you need.
Notice all the newer ones have drop down hinged doors - might have been a new invention for aistream Just never occured to them in the late 60's early 70's hmmmm
05ModPod is offline   Reply With Quote
Old 07-21-2005, 03:03 PM   #9
If anyone knows anything about things falling off of an old Airstream, it's Sharon! She is an expert!
Anon is offline   Reply With Quote
Old 07-21-2005, 05:30 PM   #10
Really Cheap
tmcdougald's Avatar
Now that I look at it seams that its supposed to come off. Just hope I dont forget to latch it and it falls of on the interstate
Veterans Fall In! Ultradog Our Community 1004 02-10-2024 11:50 AM
Fall color: where are you finding it? maxandgeorgia On The Road... 50 10-20-2004 05:12 AM
VAC California Fall Rally 63flyingcloud WBCCI Rallies & Events 8 10-08-2003 04:05 PM
First big trip Dbraw On The Road... 4 04-18-2003 08:45 PM
colorado fall get together paul k Our Community 1 09-01-2002 06:51 PM
