Old 08-22-2011, 07:44 PM   #1
2005 16' Safari
Ottawa , Ontario
Is rear hatch insulated ?
Am replacing rear floor and insulation under the bed . Wondering if I should dismantle the hatch to fill it with spray foam . Has anyone ever looked inside this ? Is there pink fibreglass in there or just air ? Looks like quite a job to dismantle . How about just drilling a hole and spraying in some foam ?
Peter Housto is offline   Reply With Quote
Old 12-06-2011, 10:12 AM   #2
Air-Texas's Avatar
2004 34' Classic S/O
Waldorf , Maryland
What did you find out? I might want to spray some foam in it too.
Mike, Miho &
Dallas the Bourbon Boxer
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
"Eva" 2004 Classic Limited 34' S/O
"Wall-E" 2012 Ford F250 King Ranch
Air-Texas is offline   Reply With Quote
Old 12-06-2011, 10:19 AM   #3
1974 Argosy 20
Kooskia , Idaho
I don't know if it is insulated or not, but don't just drill a hole in it and try to fill it with spray foam. I once had a Trail Mite 13' fiberglass trailer with two shells, inner and outer. No insulation inbetween. I made the mistake of spraying foam in a can between the inner and outer walls. It expanded and bulged both walls. Even the "minimal expanding" might have issues and could bulge your flat panels on the AS.
Just a heads up here, don't repeat my error.
Old 12-06-2011, 10:20 AM   #4
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
Mine was insulated with fiberglass. I reinsulated with Prodex.
SilverHoot is offline   Reply With Quote
Old 12-06-2011, 11:06 AM   #5
1969 27' Overlander
Albuquerque , New Mexico
Airstream brochure for 1969 models lists the cargo hatch as "insulated".
What they mean by insulation, I don't know, but it's probably the same stuff they used everywhere else: fiberglass.
Spray foam won't work if there's fiberglass in there already. Plus, it really DOES expand A LOT. It could bulge the skins.
Better to dis-assemble (PITA), and do it right.
Ed Glenn
edglenn is offline   Reply With Quote
Old 12-06-2011, 02:51 PM   #6
dznf0g's Avatar
Oswego , Illinois
I don't know where, but I was told somewhere that the newer ones have foam board or styrofoam sheet in them. I cannot remember if ti was on a plant tour or somewhere here in the forums.
-Rich-
Old 12-06-2011, 04:29 PM   #7
Air-Texas's Avatar
Waldorf , Maryland
I have seen that! Don't ask me where....
Mike, Miho &
S/OS#069
TAC # TX-33
WBCCI #5702
AIR #60387
Old 12-07-2011, 07:28 PM   #8
2005 16' Safari
Ottawa , Ontario
I removed the lock/handle assy and could see fibreglass type insulation but not a lot . I was able to squeeze more inside . I worried the spray foam could expand with enough force (I am told) to bulge the soft aluminum . Has anyone tried it ?
Old 12-07-2011, 07:39 PM   #9
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Don't sweat the small stuff
Try to keep all of this in perspective. The whole trailer is really not well insulated by today's standards. So I would suggest not worrying about one access door.
Ken
Old 12-08-2011, 08:33 AM   #10
1969 27' Overlander
Ken
Yep. Ken's right.
Ed Glenn
Old 12-09-2011, 05:10 PM   #11
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
Originally Posted by edglenn View Post
Yep. Ken's right.
Yeah, what are the window's even made of these days?
I definitely did the bare minimum with insulation on my 1959. 1.0 to 1.5" of usable insulation space and single pane super thin glass windows and ribs that are great at transferring heat in a metal skin to metal skin interface, and I have no hope.
So far the only really effective thing I've seen is Darkspeed's use of ceramic coating. If I was doing a large scale renovation for more use than weekend camping, I would go that route.
For a small compartment door only, do what you can with fiberglass, prodex, or foamboard, and get back to camping
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 12-09-2011, 07:27 PM   #12
2005 16' Safari
Ottawa , Ontario
Ken has a point . The amount of insulation between those cold inner and outer walls is negligable ! However the compartment under the bed accessed by the hatch is the coldest place inside the trailer (other than the fridge).
Old 12-09-2011, 08:32 PM   #13
Ag&Au's Avatar
I have never heard of anyone doing it, but maybe some small heat source under the bed might help make a night more pleasant. I am guessing that running a small duct from the furnace would probably involve going under the floor. Our bed has three drawers in the base. If those were left partially open, the under bed area would probably be a bit warmer.
Our mattress is a fairly thick inner spring, so the temperature of the base has not been a problem. However I can see how it could be if the mattress was thinner.
Ken
Ken
Old 12-09-2011, 09:03 PM   #14
1959 17' Pacer
Ken
Ken
Better yet, a water bed, with a water pump that recirculates through the hot water heater.
J/k it'd be fun to experiment, but can you say rear end separation?
- Peter (and Marie)
TAC CA-15
Rear End Separation Permanent Fix? dmand001 Repairing/Replacing Floor &/or Frame 23 07-24-2017 02:12 PM
How does my rear end look? desertair27 Repairing/Replacing Floor &/or Frame 35 02-23-2013 11:24 PM
Safari rear storage hatch dimensions Goal15 Exterior Storage Compartments & Access Doors 2 05-07-2011 10:48 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
