Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Exterior Storage Compartments & Access Doors
Old 03-21-2009, 12:26 PM   #1
Profile:  1974 31' Sovereign
beautiful downtown Aurora , Ontario
Send a message via ICQ to Aage
I saw a door today, oh boy
It was on a 1974 Land Yacht Tradewind. The door itself appears to be in good condition, other than some sticking of the inner screen door at the bottom where a section of the peal-and-stick door gasket had changed allegiance and stuck to the frame.
However, while the door for the most part looked true and flush when closed, at the top right corner it appeared to be warped, and stuck out maybe a half an inch from the frame. Far enough out so that the rubber gasket was visible.
Of course, this put me off the TT right away, since this seemed to be an obvious area for the ingress of water. But after returning home, I wondered: is this a difficult repair to do, but more importantly, what could have caused it?
The road to a friend's house is never long. (Old Danish Saying)
Old 03-21-2009, 12:51 PM   #2
Profile:  1994 30' Excella
Mississauga , Ontario
Maybe the door swung open forcefully in a gust of wind.
I have a funny feeling that these curved doors are not too easy to straighten out.
There was a thread on the forum about a year ago about someones attempts at straightening one. I can't remember if he was successful.
Al
Old 03-21-2009, 12:53 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
The suicide door comes open while underway. The latch stops at the side wall (damage there or not), but the front top & bottom corners still have quite a bit of inertia. The result is a bend to the door's internal skeleton. You'd note that the door frame on the hinge side isn't deformed nearly as much.
This is only a small number of hits about sprung doors.
Another sprung door
Cry Me A River... Bent Door - Dented Side
Bent (?) Door
Entry Door Frames Cast vs Extruded
Door Sprung? Repair or Replace?
Old 03-21-2009, 02:20 PM   #4
Diesel1's Avatar
Profile:  1967 24' Tradewind
Kingman , Arizona
My door frame was broken about halfway between the bottom and the latch. I removed the door, drilled the rivets and removed the inner sheeting. took the door to work and heliarced the door frame back together. It fits nicely now. Adios, John
Diesel1 is offline   Reply With Quote
Old 03-21-2009, 03:00 PM   #5
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Originally Posted by Aage View Post
I saw a door today O boy
Two thousand holes in Blackburn Lancashire
Pay no attention to the man behind the curtain- WoZ
Old 03-21-2009, 03:27 PM   #6
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
If the door is just sprung and not creased I would say it can be straightened. The reason I say this is because I helped a friend straighten his door when we were on the road this Jan. His was out almost 1 1/2 at the bottom.
He had cut a couple of 2x6s to the correct curvature, using the door frame as a template, and with several bar clamps we pulled the door back into alignment against the wooden forms. If you attempt this once the door id clamped in the correct formation you will have to shock the door with a hammer and wooden block to cause the aluminum to relax in the correct position.
Should have taken some pictures because most are not going to believe this story.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 03-21-2009, 07:45 PM   #7
And though the holes were rather small...
Old 03-21-2009, 09:30 PM   #8
Well-Preserved
overlander63's Avatar
I just had to laugh.
(No Longer at Inland RV)
Old 03-21-2009, 08:44 PM   #9
Well, while it does seem repairable, the particular trailer I saw needed other things that, when added to that door just take it off the table for me.
Bob (CanoeStream),
Oy, I read most of those threads, and oh, the pain, the suffering, the bending and the hammering... And so many ways to do it! Thanks for the links, but that was the icing on the cake.
Old 03-21-2009, 11:50 PM   #10
Profile:  1987 23' Sovereign
Tucson , Arizona
Now we know how many doors it takes to fill the Albert Hall ?
Rick
Campaz is offline   Reply With Quote
boy oh boy! my new '56 flying cloud! urbanfood 1956 Flying Cloud 162 04-23-2009 01:43 AM
Oh boy, what a day! bobfowler 2007 Safari 21 08-11-2007 12:00 PM
My boy Kai turns three today! (Picture Heavy) cameront120 The Pet Forum 9 06-07-2007 10:20 PM
Oh boy, Oh boy till Our Community 19 05-05-2005 08:26 PM
