Old 12-15-2005, 07:23 PM   #1
Wardinbb's Avatar
1964 24' Tradewind
Big Bear Lake , California
Hinged Service Door?
Has anybody done this to their 60s AS? Id like to and am having some difficulty resolving the details.
I recently completed some rear end work ( www.airforums.com/forums/f116/feel-fear-do-anyway-13551.html , the last 2 posts if youd like to see) and fabricated a new service door as part of the effort. I made two errors in judgment. Although I measured the extrusion opening MANY times, it was still wrong. And I also deemed that beefier was better. I went with .040 aluminum thinking stronger was better. We calculated that the bend radius would just fit into the .25 extrusion at the top with a few thousandths to spare. That didnt work either! It fits tightly in the extrusion on the street side (bend radius) and barely catches it on the curbside (wrong dimension!). Plus you, or shall I say I, cant get a weather seal on it either.
So Id like to use a concealed hinge mounted on the curbside so it will swing away when in use rather than getting damaged on the ground or left behind. Ive mocked-up a flush mount door/panel that takes the top extrusion out of play and have tried two different types of hinges and it aint working. So I thought Id ask.
Ed
Wardinbb is offline   Reply With Quote
Door Catches niftypkg Doors & Locks 4 05-22-2007 06:09 PM
1965 Main Door buckmaster 1965 - 1969 Globetrotter 0 10-19-2002 08:47 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 06:53 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 09:31 AM
