Old 05-21-2015, 07:00 AM   #1
1972 29' Ambassador
harvard , Massachusetts
Help! Lost a hatch cover!
My new (old) Airstream International Ambassador 29-foot 1972 came home in all its glory, but sadly had shed a hatch cover on the way.
I retraced my driving route but could not find it. I have no idea how I am going to replace that finely crafted piece of aluminum, so I hope you can help me!
Thanks, Bob
drbobdouglas is offline   Reply With Quote
Old 05-21-2015, 07:01 AM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Airstream salvage yards are the most economical answer.
Old 05-21-2015, 07:56 AM   #3
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I have one of those hatch covers for sale.
Pm if you're interested.
Mike
desertair27 is offline   Reply With Quote
Old 05-21-2015, 07:59 AM   #4
SteveH's Avatar
Common Sense , Texas
Thanks, Bob
And before you tow the trailer again, I suggest you re-rivet the battery compartment door on. They have a history of failing, and when they do you also loose the battery, and it's wiring. They are even harder to replace than the hatch cover.
Regards,
Steve
Old 05-22-2015, 07:15 AM   #5
'78 Sovereign
1978 31' Sovereign
Santa Rosa Beach , Florida
Mike
Desert air is there any chance you might have a water heater access door for a 67 over lander 27?
frankrightbrain is offline   Reply With Quote
Old 05-22-2015, 07:50 AM   #6
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Do you have a picture of your water heater or the door you need?
Old 05-22-2015, 08:27 AM   #7
mandolindave's Avatar
For future reference to those who lose a door
I found it easier and way cheaper, to make one.
I lost my refer access door. The one company who made them stopped doing so because the doors often did not fit.
I made one, and it looked great. $
I later found one off of a junker, and installed it with hinges. $$$
My next thought would have been to try Jackson, or a metal shop $$$$$
mandolindave is offline   Reply With Quote
Old 05-22-2015, 08:58 AM   #8
'78 Sovereign
1978 31' Sovereign
Mike
desertair27 do you have a water heater access door for a '67 Overlander by chance? Disregard the post above. I missed the edit window of 30 minutes.
Old 05-22-2015, 09:10 AM   #9
'78 Sovereign
1978 31' Sovereign
Unfortunately no. The water heater was removed in an aborted rear bath floor repair when I bought it. The access door was missing. I'll post a picture in a couple hours.
Old 05-22-2015, 09:39 AM   #10
mimiandrews's Avatar
1966 22' Safari
Hilltop Lakes , Texas
frankrightbrain, I have a water heater door assembly off our '66 Safari. No pics available right now. Could this be what you are looking for? PM me if you think it would work.
Old 05-22-2015, 09:54 AM   #11
1972 25' Tradewind
fort lauderdale , Florida
I have a spare for sale as well. I think mine is from a 72, but if you post me the opening dimensions, I'll measure mine this weekend.
thanks
ehodg66 is offline   Reply With Quote
Old 05-22-2015, 01:12 PM   #12
'78 Sovereign
1978 31' Sovereign
Thanks y'all, sorry Bob for the hijack. Working with desertair27.
Old 05-22-2015, 03:06 PM   #13
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Compartment door
DesertAir27 will have what you need, he has helped me with parts that a PO sold of my unit after I purchased and prior to picking it up. Saved me a lot of time looking. Jim
cole3444 is offline   Reply With Quote
Old 05-31-2015, 09:34 PM   #14
1968 20' Globetrotter
Mansfield , Massachusetts
help I lost my rear compartment door too!
I lost the entire back panel that covers the battery and piping on my 1968 Land Yacht and also has the license plate mounted on it. It came off somewhere between Cambridge Mass and Saco ME on Friday May 29 2015. Please contact me is you found it, have one or know where I could get one made. I am so disappointed.
LiisaNiemi is offline   Reply With Quote
Old 06-01-2015, 09:25 AM   #15
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Do you have any measurements and pictures of your lost hatch?
Old 06-01-2015, 11:56 AM   #16
1968 24' Tradewind
Carlsbad , California
Liisa,
The rear baggage door on the '68 is relatively easy to make. VTS has the extrusions for the door and all of the hardware (handle, bulb seal, cam-lock); you would need a piece of 2024 aluminum for the panels. All-in it should cost you about $150.
I've rebuilt mine and replaced the seals. It's a few hour project to do.
shilgemann is offline   Reply With Quote
Old 06-02-2015, 07:22 AM   #17
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I've made some compartment doors with the VTS extrusion, they turned out good but it wasn't all that easy to make the mitered cuts. I have a used rear door and I know Silver Trailer supply has doors from time to time. Just make sure you take good measurements because there are some different sizes,I found this out the hard way.
Mike
Old 06-05-2015, 01:27 PM   #18
1965 26' Overlander
Edmonds , Washington
Are there any threads showing how to make a replacement compartment door with the VTS materials? I need to make three and I'm stumped.
Thanks!
FullStop is offline   Reply With Quote
Old 06-07-2015, 11:58 AM   #19
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
I don't know of any threads. Check with Vintage Trailer Supply on how to make door
Old 06-07-2015, 11:59 AM   #20
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
It's not to bad
a Hatch, I want a hatch snkrichards General Repair Forum 4 05-17-2012 09:56 PM
Missing Hatch Cover bevman Exterior Storage Compartments & Access Doors 4 03-19-2008 01:50 PM
Bumper Hatch Cover campngirl Bumpers & Bumper Storage 12 10-20-2006 08:10 PM
63 Overlander Hatch Dome Cover squrlgurl Roof Vents, Skylights & Fans 11 01-06-2006 10:17 PM
