Old 04-14-2011, 09:19 AM   #1
TPdrums's Avatar
1972 27' Overlander
Mo Hill , California
Hatch hinge material
I'm redoing my gaskets and cleaning all my doors and windows. Upon taking them apart to clean up, its apparent that two off my access hatch doors will not take the worn out hinge material that was on them before. It looks like they have been dropped a few too many times... AS no longer makes this hinge though. Any ideas from anyone on where I can get more?
It's the 'J' style extruded hinge material on the lower hatches that I am looking for. My coach is a '72 overlander.
Todd
Fine Woodworking, Furniture, Carpentry, Drums, and Lutherie
www.ToddCreatedWood.com
http://toddcreatedwood.blogspot.com/
TPdrums is offline   Reply With Quote
Old 04-14-2011, 10:18 AM   #2
Todd
Takr the hinge off the door.
Get some 1 inch "piano" hinge material.
Install the first half of the hinge at the bottom of the door.
Then, place what was the top of the door, at the bottom, and then rivet the other half of the hinge in place, to the door frame.
Now the door will be hinged at the bottom, plus when you open that door, it simply swings downward, but stays attached to the trailer. Can't lose the door or run over it.
10 to 15 minute job.
Old 04-14-2011, 10:56 AM   #3
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
In case you'd like a picture of what this modification looks like (post #22): http://www.airforums.com/forums/f185...b-50967-2.html
Chris
Old 04-14-2011, 11:02 AM   #4
Chris
Yup, that's it.
Thanks Chris.
Old 04-15-2011, 04:13 PM   #5
TPdrums's Avatar
1972 27' Overlander
Thanks all, I'm aware of the piano hinge trick, but I am not interested in that as it looks a bit clunky. I like being able to remove them too. I was hoping for someone who may know of a place for buying used parts, or salvage yards to find the stock hinge...
Old 04-15-2011, 07:11 PM   #6
Minno's Avatar
1972 31' Sovereign
Try Colaw's Salvage yd in Missouri. They have Airstreams they are parting out, as well as some new parts for sale. Never been there but we just bought a new bathroom sink from them and it came in 2 days!
Kay
Old 04-19-2011, 11:51 AM   #7
TPdrums's Avatar
1972 27' Overlander
Spoke with Colaw's, and boy was that a waste of time. They were full of themselves and totally unhelpful.
Old 04-24-2013, 07:14 AM   #8
1969 27' Overlander
Boise , Idaho
TPDrums, I've got a similar problem. My doors were not well-treated by the PO. The part of the hinge attached to the doors are badly bent out of shape. If you come up with a replacement, please let us know. If not, I plan to take a shop at repairing these.
Aluminum is malleable if worked gently and patiently. I figure some bench vise and hammering should flatten out the flat part of the hinge (where the rivets attach it to the door). I'm then hoping I can figure out the radius of the curve on the portion that slides into the trailer-mounted half of the hinge, by trying various pieces of steel rod on an existing hinge in good condition. Then the plan would be to hammer (gently, patiently) the aluminum around a piece of rod.
Don't know if it will work or not, but would gladly accept any input or thoughts before I begin.
Jamespio is offline   Reply With Quote
Old 04-24-2013, 08:14 AM   #9
The fix is "don't".
Remove the hinge from the door.
Turn the door upside down and install a hew hinge at the bottom.
In that way, the door always stays attached to the trailer and you will never have another access door hinge problem again.
Many owners have already done that.
Also, you will not be able to leave the door behind, or run over it either.
Old 01-31-2014, 07:27 AM   #10
Jim & Mitzi's Avatar
1987 32' Excella
1990 29' Land Yacht
Americus , Alsrural Bristol Tn.
Suggest a rust proof hinge -aluminum or brass....
Jim & Mitzi is offline   Reply With Quote
Old 01-31-2014, 07:42 AM   #11
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Not brass. Brass and aluminum are pretty far apart on the galvanic scale, and galvanic action between the two will evenually cause the aluminum to corrode if the hinge is exposed to moisture.
Cats and ultraleather Airstream upholstery don't mix!
Replacement flooring material polarlyse Repairing/Replacing Floor &/or Frame 10 04-01-2011 04:07 PM
Need back hatch for my 1964 Safari Safari Bob Exterior Storage Compartments & Access Doors 5 03-08-2011 07:52 AM
Exterior gasket material? NicheVintage Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 01-31-2011 08:56 PM
Will gasket material seal the rear bumper storage? tvanwave Bumpers & Bumper Storage 0 01-31-2011 04:00 PM
