Old 08-25-2009, 09:45 PM   #15
1960 24' Tradewind
Riverside , California
Miscellaneous Parts
ABS trays available here
Greg
ZoomZoom is offline   Reply With Quote
Old 09-15-2009, 05:21 PM   #16
1956 22' Caravanner
Sarasota , Florida
Sewer solution?
Originally Posted by AirHeadsRus View Post
These were mounted by the PO. I was told it was used to haul their flag poles. Access is only from the curb side on mine so I doubt they stored the sewer hoses. My flag pole was to long to fit in it. Need to get some that will. I just got my Sewer Solutions so am getting rid of all but one emergency slinky. Yipee!
Joe
Hi - we are new to this and have begun a total restoration of a '56 Caravanner. We are putting in all new plumbing and tanks, etc.
Here's the question: What is a SEWER SOLUTION??
LuckyLindsy is offline   Reply With Quote
Old 09-15-2009, 05:36 PM   #17
davenpow's Avatar
1975 31' Sovereign
Canby , Oregon
LuckyLindsy,
Google it and then hit the first response for a explanation (ad).
ted
davenpow is offline   Reply With Quote
Old 09-15-2009, 05:37 PM   #18
DEITZ645's Avatar
2006 30' Classic S/O
Mohrsville , Pennsylvania
LuckyLindsy,
You can find out what a Sewer Solution is on their web site...
Sewer Solution
Now you know.
Carl, Elaine & Finn The Beagle
2006 30' Classic W Slide & Limited Package Katarina
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
S/OS#042
AIR #14487
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-15-2009, 05:45 PM   #19
1956 22' Caravanner
Sarasota , Florida
Thanks for the info....it looks great.
Old 09-15-2009, 07:22 PM   #20
Airstream Newbie
Torrance , California
One other question on this.. Would it not be a good idea to put a small vent in each end of the PVC lid to allow air to get in so things can dry out --? Just an idea.. I would think leaving 'wet' stuff in there for a long time might not be a good idea.. Perhaps there's a hole in there but I didn't notice one in the photos
Rick F is offline   Reply With Quote
Old 09-20-2009, 07:04 PM   #21
Ours has about 10 - 1/2" holes drilled on the underside all the way across. The tube came from the factory, not sure about the drain holes.
Old 09-20-2009, 09:06 PM   #22
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
Originally Posted by eubank View Post
I've seen these on a bunch of rigs. One feature to design in would be a wider opening at the end. The problem is that many of these are designed to hold the hose, but not the fittings on the hose, so folks have to remove the fittings in order to store the hose.
Lynn
I have two factory installed carriers on my trailer. One holds the primary slinky with a 45 elbow connector to the trailer. The other holds the backup/extension slinky with extension coupler already attached.
Michelle TAC MT-0
Sarah, Snowball
Old 09-20-2009, 11:34 PM   #23
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I installed one on our '65 Caravel some years ago. I drilled several 1/2 inch holes in the end caps to allow some air flow to dry out the hose. Works well. Much nicer to deal with a dry hose.
Old 09-21-2009, 07:40 AM   #24
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
We had two extra tubes installed at the factory as part of our original build - they carry the extension and backup hoses so I can use the bumper compartment for other things.
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Window modification rmpray Windows & Screens 1 02-21-2008 08:01 PM
Bedroom modification geodrake Cabinets, Counter Tops & Furnishings 0 10-15-2007 06:46 PM
Modification Required For Uk maggi1972 Shipping & Export/Import 3 08-12-2007 02:48 PM
Wardrobe modification - 73 Sovereign ptbasmith Member Introductions 2 05-06-2006 01:37 PM
CCD Modification frozen chosen Airstream Trailer Forums 0 04-07-2004 07:29 PM
