Old 09-07-2010, 09:33 AM   #1
1995 36' Classic 36
Orangevale , California
Front Hood Piston supports worn out
My 95 Classic has a front hood where the batteries and leveling pumps are located. The hood is supported when open by two spring loaded rods that don't have any enough spring left to keep it open. The mfg is QMP Inc in Elkhart Indiana. Haven't heard back from them yet, but am looking at perhaps a gas rod replacement if they can't help. Where would you go to get new rods and what do you need to watch our for?
Pomfritz is offline   Reply With Quote
Old 09-07-2010, 11:19 AM   #2
banjobill
wmarsha's Avatar
2000 30' Limited
battle ground, , Washington
original best if it worked right for a long time
gas struts can be purchased from NAPA. You have to choose the following: 1)types of ends 2) open and closed length(s) 3) diameter 4) lifting capacity
Now, these things are usually marketed as replacement units for some original application. But, the mfg catalogs of the unit(s) will give the above info. The tricky part is knowing the weight of what you are lifting(try to use a scale to open said unit). The Diameter allows you to get a relatively shorter piston with relatively greater lifting capacity. Ie: if you need 20 lb lift, you may get it with a 12 inch 3/4 inch piston, or if that is too long, then a 1 inch piston 8 inches long. Now this example is just that-it has no factual info within.
What you have to watch for it the placement of the ends such that the piston collapses correctly and does not try to go "overcenter" when open. Such a condition will negate the ability to close correctly. Also the ends can be expensive, so look for the simplest method of attachment. good luck
wmarsha is offline   Reply With Quote
Awning supports Minnie's Mate Awnings 9 12-06-2008 11:11 AM
64' rock cover arms ( supports ).. need help campngirl Rock Guards, Segment & Window Protectors 15 07-16-2007 10:50 AM
rail supports for argosy beds brettc Member Introductions 3 01-27-2006 04:47 AM
Interior Rear Supports?? BornToRock General Interior Topics 0 08-23-2005 10:54 PM
Gas Line Supports Falling Off gklott LP Gas, Piping, Tanks & Regulators 5 06-23-2005 02:42 PM
