Old 11-10-2014, 05:13 AM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Front door key hole getting loose
Hi- After locking and un locking the front door for the past seven years..I have noticed the place where the key is inserted is getting loose acting. I saw a help link a while back about the front door lock fix / repair. Does anyone have a help out tip or the link?
Thanks!!
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 11-10-2014, 05:33 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Once the mechanism gets worn, there's no fixing it except to replace the whole lock.
But before you do that, see if it's the lock itself or the key that is worn. If you have a spare key, compare the two keys and see if one is worn down more than the other. The key is made of softer metal than the lock and should wear faster than the lock tumblers. The fix might be as simple as using a new key.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
What is this hole on my street side front exterior? ajcannon Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 05-19-2013 02:52 PM
Is my weep hole on front window from PO tx70amb Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 11-03-2009 09:53 PM
Door hinges loose Blimphauler Doors & Locks 7 11-20-2006 03:22 PM
How to tighten loose pocket door? tkoch General Interior Topics 1 09-04-2005 04:50 PM
Loose exterior door hinge bolts JoeGillis Doors & Locks 2 10-21-2002 11:11 AM
